siearl Posted November 9, 2007 Share Posted November 9, 2007 All, Just looking for some clarifacation, i was having trouble with the 110 just cutting out on me as i was driving along, i thought i had sorted it by finding a problem wire on the fuel pump. if the wire was still broken would just normal driving on a straight road affect it. Thanks all Engine is a 3.9 V8 efi and the wire in question is where the ecu and fuel pump relay are. Quote Link to comment Share on other sites More sharing options...
Earl Posted November 9, 2007 Share Posted November 9, 2007 May be Quote Link to comment Share on other sites More sharing options...
siearl Posted November 9, 2007 Author Share Posted November 9, 2007 Adrian, try not to use to many words LOL Quote Link to comment Share on other sites More sharing options...
Earl Posted November 9, 2007 Share Posted November 9, 2007 Si can you run a temp wire from the batt to the pump (with a fuse in it) and see if it works OK you will have to remove the supply when you stop the eng. Quote Link to comment Share on other sites More sharing options...
alex park Posted November 9, 2007 Share Posted November 9, 2007 i ran a suplly from the relay to the pump on my v8i which worked out ok and switched off with the key. then found out later it was the ignition isolator that had tripped. Alex Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 9, 2007 Share Posted November 9, 2007 If the wire was "broken" anything could affect it. The fuel pump dying would show up as a loss of power and really rough running for a few seconds then dying. I would suspect the ignition amplifier, they fail when hot and then start working again after a bit - usually the time it takes you to stop, poke a few unrelated bits and get back in. Quote Link to comment Share on other sites More sharing options...
siearl Posted November 9, 2007 Author Share Posted November 9, 2007 An Update, have found it was not the fuel pump it was the air mass meter, i had not plug the cable back in to it, however i am having ignition problems i have been through the dizzy, the cap rotor arm, ht leads, i have checked the fuel pump was working and fuel going through but all i am getting is it is trying to fire over, coughing and spluttering but it is not starting. Any one got any ideas Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted November 9, 2007 Share Posted November 9, 2007 Its probably not your problem but I spent 18months chasing a cutting out problem, replaced everything in the fuel system except the fuel tank (which was spotless inside) only to eventually spot the waxed cardboard cap from a Redex bottle floating in the tank. The damn thing caused me months of fustration and no small about of aggravation trying to retrieve it with a sharpened welding rod Will Quote Link to comment Share on other sites More sharing options...
Earl Posted November 9, 2007 Share Posted November 9, 2007 Si are you trying starting on LPG or petrol ?? Quote Link to comment Share on other sites More sharing options...
western Posted November 9, 2007 Share Posted November 9, 2007 Si are you trying starting on LPG or petrol ?? Oi get back to work, or I'll tell your Boss Quote Link to comment Share on other sites More sharing options...
Earl Posted November 9, 2007 Share Posted November 9, 2007 Oi get back to work, or I'll tell your Boss Iam The BOSS any way i here till five and working hard Quote Link to comment Share on other sites More sharing options...
siearl Posted November 9, 2007 Author Share Posted November 9, 2007 Can only try on Petrol at the moment as have no LPG in the system, trying to get it started to get up to the garage Quote Link to comment Share on other sites More sharing options...
Earl Posted November 9, 2007 Share Posted November 9, 2007 Can only try on Petrol at the moment as have no LPG in the system, trying to get it started to get up to the garage When you need a MSA recovery unit you can not find one Quote Link to comment Share on other sites More sharing options...
Orange Posted November 9, 2007 Share Posted November 9, 2007 Have you checked that the spark from the coil is big enough? I had an ignition problem before the last Shires 7 Sisters do and ended up replacing the coil. I had fuel, air and spark all at the pistons, but the spark wasn't big enough! Turns out that when people say that you beed a F BIG spark for a Rover V8, they mean that the coil needs to be throwing out a bolt of lightning!! Mght work....... Quote Link to comment Share on other sites More sharing options...
siearl Posted November 10, 2007 Author Share Posted November 10, 2007 Have found and sorted the problem now thanks Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2007 Share Posted November 10, 2007 Have found and sorted the problem now thanks so don't keep it to yourself, share it as the repair my help others, we know what the problem was how did you fix it ?????? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 10, 2007 Share Posted November 10, 2007 It's a V8 - you need to stop at garages more often to fill up Les. Quote Link to comment Share on other sites More sharing options...
siearl Posted November 10, 2007 Author Share Posted November 10, 2007 Ralph, The problem was solved with the supply of the correct parts. Rotor arm and the dizzy cap Quote Link to comment Share on other sites More sharing options...
siearl Posted November 10, 2007 Author Share Posted November 10, 2007 oh forgot to mention you get one hell of a flame out the exhaust on lpg as it backfires Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2007 Share Posted November 10, 2007 Ralph,The problem was solved with the supply of the correct parts. Rotor arm and the dizzy cap OK, but still good to know what fixed it. Quote Link to comment Share on other sites More sharing options...
