Michele Posted December 2, 2005 Share Posted December 2, 2005 Max torque peak @ almost 500Nm?!?!?!??! Quote Link to comment Share on other sites More sharing options...
Lara Posted December 2, 2005 Share Posted December 2, 2005 I think that's enough for me Halfshafts etc Lara. Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 2, 2005 Share Posted December 2, 2005 Jules, I've heard a bit more about this engine now but I still don't know much (I think we'll have to wait until Andy's finished playing in the Jungle before we get the full story ) but apparently the engine's sitting in the Bowler Wildcat that was on one of the stands at Billing. I'm a bit unsure about the figures, hopefully I'll be able to give you some figures from mine soon. You've also got a PM Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 2, 2005 Share Posted December 2, 2005 (edited) Rolands getting one on the dyno at ACR in a couple of weeks - should be interesting. still weighing up if its worth sticking a VGT on an Isuzu Will is your VGT watercooled? Edited December 2, 2005 by dollythelw Quote Link to comment Share on other sites More sharing options...
Lara Posted December 2, 2005 Share Posted December 2, 2005 Off to Africa now to play with things fitted with VBT, C U in 10 days VBT = Very Big Teeth Lara Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 2, 2005 Share Posted December 2, 2005 taking a VBG? or VPC? very big gun very posh camera Quote Link to comment Share on other sites More sharing options...
Lara Posted December 2, 2005 Share Posted December 2, 2005 VCC (Very cheap camera) in case the VBT eat me Lara. Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted December 2, 2005 Share Posted December 2, 2005 The Wildcat in question gave 380 lb/ft of torque. Apparently an article in TOR is on it's way. Still impressive for a 2.8 diesel, but at £5K plus the tuning you could buy an awful lot of petrol Chevy. To follow on from Jezs point on dyno figures. When I had my engine dynoed the chap said that quoted figures were often inflated by incorrect atmospheric conditions being programmed into the dyno. He related a tale where he demonstrated some American figures were inflated by 15%. He checked their quoted atmospheric figures against those of a nearby airport on the test date and reran the figures through at the correct calibration. I would have thought that calculating flywheel power from rolling road figures allows even greater margins of error Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 2, 2005 Share Posted December 2, 2005 The Wildcat in question gave 380 lb/ft of torque. Apparently an article in TOR is on it's way. Still impressive for a 2.8 diesel, but at £5K plus the tuning you could buy an awful lot of petrol Chevy.To follow on from Jezs point on dyno figures. When I had my engine dynoed the chap said that quoted figures were often inflated by incorrect atmospheric conditions being programmed into the dyno. He related a tale where he demonstrated some American figures were inflated by 15%. He checked their quoted atmospheric figures against those of a nearby airport on the test date and reran the figures through at the correct calibration. I would have thought that calculating flywheel power from rolling road figures allows even greater margins of error Ah, that's more like what I was expecting! 380's a very nice figure for a small capacity engine. Jez, no, the bearings aren't watercooled. I'm not sure If I'll need them as I'm not running max power/boost for long periods. Quote Link to comment Share on other sites More sharing options...
Steve H Posted December 8, 2005 Share Posted December 8, 2005 still weighing up if its worth sticking a VGT on an Isuzu Jez, Yes, I think you should & then let the rest of us know the pit falls , joking aside, seeing as the 2.8 Isuzu & the 2.8 International TGV share almost identical bore & stroke, I can't see why equally impressive results shouldn't be obtained. Wish I could remember the model Garret turbo that the 2.8 TGV runs. ATB Steve. Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted December 8, 2005 Share Posted December 8, 2005 I would have thought that calculating flywheel power from rolling road figures allows even greater margins of error Yup, it could not really be called objective, too many assumptions have to be made. The only figures you can take for real are if you rolling road the unit before modification and then compare the difference. I have a GTECH performance meter that claims to be able to be able to "calculate" the flywheel figure using inertial measuring techinques, haven't had a chance to play with it yet but it will be interesting to compare with the rolling road figures I have. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 8, 2005 Share Posted December 8, 2005 At this point, I'll plug my GPS-based technique again. The more I play with it, the more interesting the results are. I've just got to find a quiet road and some time to start messing with some variables on the engine. Will (Warne) - would you like to "GPS" your engine before and after the tuning? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 8, 2005 Share Posted December 8, 2005 Steve - its tempting but its a £700 punt just for an experiment, let me get finished whats currently under build and I'll give it a go later in the spring. Im a big fan of drive (as opposed to peak) engines and what concerns me at the mo is the low end hit and then run out of steam curve that the VGT seems to give, I want to see what Roland gets out of the one at ACR Hows you getting on with the bits and bobs collecting? fancy building the first southern hemisphere "hamburger"? ping me a pm mate and I'll send you a piccy Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 8, 2005 Share Posted December 8, 2005 At this point, I'll plug my GPS-based technique again. The more I play with it, the more interesting the results are. I've just got to find a quiet road and some time to start messing with some variables on the engine.Will (Warne) - would you like to "GPS" your engine before and after the tuning? TC, I can do although I'll have a full before and after dyno readout too Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 8, 2005 Share Posted December 8, 2005 TC, I can do although I'll have a full before and after dyno readout too In which case it would be an ideal oppertunity to directly compare TC's GPS method to the more dyno. Be interesting to see the results. Quote Link to comment Share on other sites More sharing options...
jules Posted December 8, 2005 Share Posted December 8, 2005 Will I'm thinking of going JAP they have a 3.2D which can produce with the correct tweeks 2-300 bhp and 760 fb in a much lighter truck with stronger from box axles. and Lockers from the factory I see you and I raise you (in about 12months) Jules Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 8, 2005 Share Posted December 8, 2005 *Passes Jules heavily dented tin hat* 3.2 common rail? Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 8, 2005 Share Posted December 8, 2005 WillI'm thinking of going JAP they have a 3.2D which can produce with the correct tweeks 2-300 bhp and 760 fb in a much lighter truck with stronger from box axles. and Lockers from the factory I see you and I raise you (in about 12months) Jules Who's engine's that? The torque figures must be in Nm, though (still bl**dy impressive at about 550 lb/ft ). With that sort of setup you'll need D60s or Mog axles; even with well fettled Toyota axles you'll be sailing close to the wind. I can't wait to see it, though Quote Link to comment Share on other sites More sharing options...
jules Posted December 8, 2005 Share Posted December 8, 2005 Who's engine's that? The torque figures must be in Nm, though (still bl**dy impressive at about 550 lb/ft ). With that sort of setup you'll need D60s or Mog axles; even with well fettled Toyota axles you'll be sailing close to the wind. I can't wait to see it, though No lb/ft but engine not avalible in the UK modle Your not even close Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 8, 2005 Share Posted December 8, 2005 Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 8, 2005 Share Posted December 8, 2005 Ford? Mog 404s and Lappies will cope, TLC 80s will do it but only just. Ive got a friend with 750ft/lbs cummins in his truck and U15 axles and 44's with no hassles but its F$£kin heavy nice numbers Jules - spill the beans mister? Next time you're passing stop in - a lots changed in a very short space of time Quote Link to comment Share on other sites More sharing options...
jules Posted December 8, 2005 Share Posted December 8, 2005 Very light truck so I'm hoping the strenth will do but it uses race engine tecnoligy but as standard has masive power output. The BMW 3.0 common rail has loads of power output standard and load if you start to push them. Is the 2.8 the Iveco lump rebaged Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 8, 2005 Share Posted December 8, 2005 TC, I can do although I'll have a full before and after dyno readout too As Mark says, an ideal test really - it'll be interesting to see if I get the same %age improvement as the rolling road... then it's up to you to decide which is really true! Have you got a PC/PocketPC based GPS unit? Quote Link to comment Share on other sites More sharing options...
jules Posted December 9, 2005 Share Posted December 9, 2005 No lb/ftbut engine not avalible in the UK modle Your not even close sorry I stand corrected it is Nm. Driving off a crest and down a hill I could not work out if the car was jumping and falling of powering down the hill. its that powerful and thats in a 2.7t shell the modle I'm looking at is half that. Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 9, 2005 Share Posted December 9, 2005 As Mark says, an ideal test really - it'll be interesting to see if I get the same %age improvement as the rolling road... then it's up to you to decide which is really true! Have you got a PC/PocketPC based GPS unit? TC, I can sort something out however it won't be a great curve as I'll probably do the recordings locked in 3rd gear so the torque convertor won't be locked up. Quote Link to comment Share on other sites More sharing options...
