tacr2man Posted November 29, 2007 Share Posted November 29, 2007 What fuel tank for a 110 with efi so you can use an internal hp pump ? to mount in the normal place, or is it a custom build only ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 29, 2007 Share Posted November 29, 2007 Avoiding the question totally, I stuck a diesel pickup tube in my tank and used an external pump. Quote Link to comment Share on other sites More sharing options...
R Bates Posted November 29, 2007 Share Posted November 29, 2007 When i put an efi in a 110 i had i used the tank from the donor range rover. It was a straight swap for the 110 tank. Quote Link to comment Share on other sites More sharing options...
Coastcard Posted November 30, 2007 Share Posted November 30, 2007 The 110 V8 petrol tank (believe it also applies to other models) is fine. The HP pump from Range Rover fits, but I have heard that some people extend the length of it a bit. When I measured the one I got it was the same as the original carb pump so just dropped it in and works well into red on fuel guage. The tank has a main filler tube with adjacent smaller diameter breather tube on the rear RHS and there is a small diameter return tube at the front of the RHS. The hole for the pump is in the top (if that makes sense). I do have my original (I replaced with galv) for £10 if you want it. No leaks, but does have some rust around seams. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 30, 2007 Share Posted November 30, 2007 Similar to Coastcard.... Same fuel tank in the 110 from when it was on carbs. Replaced fuel pump with the one from the RRC donor when the EFi went in... Same pump length overall but longer internal pump resevoir was longer. Picks up from the bottom of the tank no problems. Neil Quote Link to comment Share on other sites More sharing options...
tacr2man Posted November 30, 2007 Author Share Posted November 30, 2007 Thanks for the info, will look for a rangie fuel pump then, have been using an external pump but the whining gets on your nerves after an hour or two, Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 30, 2007 Share Posted November 30, 2007 .... but the whining gets on your nerves after an hour or two, I suggest leaving the wife at home....I do I can confirm the same as above - existing tank with HP pump works. There was a small amount of depth adjustment on the pump i bought - by loosening a screw & sliding the bracket a little. I bought the HP pump on ebay from one of the uk suppliers. Quote Link to comment Share on other sites More sharing options...
Millsy Posted November 30, 2007 Share Posted November 30, 2007 Similar to Coastcard....Same fuel tank in the 110 from when it was on carbs. Replaced fuel pump with the one from the RRC donor when the EFi went in... Same pump length overall but longer internal pump resevoir was longer. Picks up from the bottom of the tank no problems. Neil And three... thats how mine is set up, no worries. Quote Link to comment Share on other sites More sharing options...
