wkw90 Posted February 9, 2008 Share Posted February 9, 2008 I have just striped the oil pump , timming cover on a 3.5.v8 and where the gears sit there is some wear (see photo ) will it be ok to use this or should i be looking for a new cover Paul Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 I have seen worse, but its not good. The dizzy drive side has had something in there which has picked up (rather than just wear) and this will mean reduced oil pressure and you MUST NOT try to clean it up other than a very very good clean. As it is an ordinary cover I would suggest you get another. Your problem will be finding one that isn't as bad from a high mileage motor, make sure that you put new gears in whichever cover you use Nige Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 Anyone selling a timming cover ? Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 Just had a look at RPI secondhand timming cover £145 Quote Link to comment Share on other sites More sharing options...
SteveRK Posted February 9, 2008 Share Posted February 9, 2008 My engine has 170,000 miles and having recently replaced the camshaft my pump housing was similar - a new set of gears and pressure relief spring should suffice (not expensive) as that amount of scoring shouldnt have much affect at all on pressure bearing in mind the speed that the gears are rotating at - If it can extinguish the oil pressure light when turning the engine over with the starter on a hot engine (disconnect coil) then that would indicate more than sufficient pressure to run with. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 My engine has 170,000 miles and having recently replaced the camshaft my pump housing was similar - a new set of gears and pressure relief spring should suffice (not expensive) as that amount of scoring shouldnt have much affect at all on pressure bearing in mind the speed that the gears are rotating at - If it can extinguish the oil pressure light when turning the engine over with the starter on a hot engine (disconnect coil) then that would indicate more than sufficient pressure to run with.Yep after looking around i think mine is not that bad so a good clean, new gears ect and back on it goes . I am thinking if i keep the oil clean there should be a few miles in it yet ...... Paul Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 Er - Wrong The wear on the RHS is OKish the LHS is not. When you removed the gears did you mark the mesh as to which teeth were connected - if not then bin them - use the old and remeshed they wear fast re-seating themselves if you then wastye more money on new gear - the new gears will now be fitted to a badly worn base - this will worsen the wear as they bed in Frankly the wear is too much - there are thousands of V8s out there, find one where the RHS is about the same on both sides, otherwsie why are you bothering to "Rebuild" the engine, at the end of the day the oil pump / pressure is the heart of any engine V8 or anything else Would you shove a scored piston in, or a chipped ring and say "Its ok ?" £20-£40 should see you with a decent timing cover Nige Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 Er - WrongThe wear on the RHS is OKish the LHS is not. When you removed the gears did you mark the mesh as to which teeth were connected - if not then bin them - use the old and remeshed they wear fast re-seating themselves if you then wastye more money on new gear - the new gears will now be fitted to a badly worn base - this will worsen the wear as they bed in Frankly the wear is too much - there are thousands of V8s out there, find one where the RHS is about the same on both sides, otherwsie why are you bothering to "Rebuild" the engine, at the end of the day the oil pump / pressure is the heart of any engine V8 or anything else Would you shove a scored piston in, or a chipped ring and say "Its ok ?" £20-£40 should see you with a decent timing cover Nige I feel like i ve been told off . Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 Oi Did I tell you you could come out of the naughty corner yet young man no, but seriously if you are 2Doing a rebuild" why bother if your going to fit back on the engone an oil pump which at best is "Past its best" ? An oil pump is the heart of any engine, a decent second hand cover giving you a pump unit worth the expense of new gears is worth every penny. Yes I am fussy, but I have spend 20+ years with V8s and that timing case would go int he skip, I wouldn't either use it nor even think of selling it as the LHS is past it If you wnated to shove an engine togehter for say a V8 Racer, where anytrhing would do as it was going to have the naggers thrapped out of it and it lasts as long as it does (know of 3x of these and frankly they still go on - one was build out of bits I was either binning or had on the FLOOR of my shed ) they fine, but your not ? Think about it, and maybe others who have a knowledgfe of working on V8s may like to comment ? Ian are you about ? Nige Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 OiDid I tell you you could come out of the naughty corner yet young man no, but seriously if you are 2Doing a rebuild" why bother if your going to fit back on the engone an oil pump which at best is "Past its best" ? An oil pump is the heart of any engine, a decent second hand cover giving you a pump unit worth the expense of new gears is worth every penny. Yes I am fussy, but I have spend 20+ years with V8s and that timing case would go int he skip, I wouldn't either use it nor even think of selling it as the LHS is past it If you wnated to shove an engine togehter for say a V8 Racer, where anytrhing would do as it was going to have the naggers thrapped out of it and it lasts as long as it does (know of 3x of these and frankly they still go on - one was build out of bits I was either binning or had on the FLOOR of my shed ) they fine, but your not ? Think about it, and maybe others who have a knowledgfe of working on V8s may like to comment ? Ian are you about ? Nige Ok dad , but whats an engone Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 Its that thok in your Lung River son Now, clean your room up and get to bed and read that magazine "Non F'd LR Bits Monthly" Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted February 9, 2008 Share Posted February 9, 2008 I feel like i ve been told off . Well to be honest, you have But its for your own good For the reason Nige has pointed out above, if your just building a motor with a potential limited lifespan, then go for it. But if your rebuilding with the long term in mind, then bin it. Nige has listed many valid mechanical reasons, but also, if you are re-building - do it properly, what happens in the pub V8 blah blah talk? - you would be shamed! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 Rog, Leave him alone, ........he's cleaning his room up Nige Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 9, 2008 Share Posted February 9, 2008 A Tdi lump is looking cheaper and cheaper, Paul [Col. Kilgore on]I love the smell of diesel in the morning [Col. Kilgore off] Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 And don't it look nice for the bin Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 Col. Kilgore was as all know who have seen the film completely deranged and the correct quote is : [Col. Kilgore on]I love the smell of <cough>diesel<cough> in the morning Nurse sponge please [Col. Kilgore off] Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 9, 2008 Share Posted February 9, 2008 When you're doing an engine rebuild it's never worth cutting corners. Les. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 A Tdi lump is looking cheaper and cheaper, Paul [Col. Kilgore on]I love the smell of diesel in the morning [Col. Kilgore off] Mo Never Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 "That's Ma Boy" And get a haircut too Nige Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 "That's Ma Boy" And get a haircut too Nige Ill get in there before Mo about the hair i have none Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 9, 2008 Share Posted February 9, 2008 Ill get in there before Mo about the hair i have none F me - we are related Nige Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 10, 2008 Share Posted February 10, 2008 Looks like Uncle Nige has taken you under his wing Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 I ve got a nice roof for you Quote Link to comment Share on other sites More sharing options...
muddy Posted February 10, 2008 Share Posted February 10, 2008 I could swear i can hear the dueling banjo's in the background Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 10, 2008 Share Posted February 10, 2008 Ahhh yes, a TDi seems like such a good idea doesn't it? When something goes wrong it's always money, frankly £40 for a front cover seems like small change Just think of all the money you're saving on elastic bands In fact when I came to find this picture I've realised that half the TDi owners I know have had major engine failure (cambelt, cracked head, head gasket, melted piston...) at least once in the last couple of years, whereas I don't know of any V8's that have gone wrong beyond the usual moist electrics. Quote Link to comment Share on other sites More sharing options...
