CR88 Posted March 4, 2008 Share Posted March 4, 2008 Hi, Some time ago (some years ago) I found one article in the LRO magazine where it was presented how to fit an VW Polo heater in a SIII. Anyone knows what I'm talking about and where I can find it? Regards, Quote Link to comment Share on other sites More sharing options...
MECCANO Posted March 4, 2008 Share Posted March 4, 2008 I'd be interested in seeing this aswell Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 4, 2008 Share Posted March 4, 2008 I've got a defender one in mine. Works well and is pretty easy to fit. Jon Quote Link to comment Share on other sites More sharing options...
CR88 Posted March 5, 2008 Author Share Posted March 5, 2008 I've got a defender one in mine. Works well and is pretty easy to fit.Jon Yes, I agree with the solution and is alternative, but I'm looking for a really alternative solution. I search in my eldest LRO but no luck so far. I remember one handy fellow that fit in a very straight way the VW Polo heating system under the bonnet in a SIII. Any idea where I can find it??? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 5, 2008 Share Posted March 5, 2008 This is an indirect lead, but try this link http://www.kenner.ca/RoverWeb/mailinglist-...01/01/0001.html note that it goes back to 2003, and that one of the links is dead, BUT you can see Harald Hansen's email so you could try him directly, or join the list and ask. Along the same lines, try contacting StrangeRover from this thread. http://www.landyzone.co.uk/lz/f6/arctic-he...cher-21371.html Cheers. Quote Link to comment Share on other sites More sharing options...
CR88 Posted March 5, 2008 Author Share Posted March 5, 2008 David, thanks (Y) Quote Link to comment Share on other sites More sharing options...
Serious Series Posted March 5, 2008 Share Posted March 5, 2008 David, thanks (Y) Seems a complex way to get round the old heater problem I used a 2nd landrover Matrix and altered casing to suit see attached photo's now have to drive with vents open as my heater valve does not shut completely. Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted March 5, 2008 Share Posted March 5, 2008 Doesn't the defender item fit? What about a Fuel burning heater? Surely a Freelander in a breakers yard might yield something? Or Erberspacher? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted March 5, 2008 Share Posted March 5, 2008 IIRC the matrix from an Austin or Rover Metro is the same size as the series Landy one, but the pipes come out at the wrong angle, but perhaps it may be fitted with a bit of messing. Quote Link to comment Share on other sites More sharing options...
Phill B Posted March 7, 2008 Share Posted March 7, 2008 Hi,Some time ago (some years ago) I found one article in the LRO magazine where it was presented how to fit an VW Polo heater in a SIII. Anyone knows what I'm talking about and where I can find it? Regards, I'm probably stating the obvious but if you know the month and year you could order a back issue. Quote Link to comment Share on other sites More sharing options...
CR88 Posted March 7, 2008 Author Share Posted March 7, 2008 I'm probably stating the obvious but if you know the month and year you could order a back issue. If I only knew... I hope you have a better memory then me To be honest I don´t know, I only remember that I saw it. Quote Link to comment Share on other sites More sharing options...
david1701 Posted March 9, 2008 Share Posted March 9, 2008 Have you tried emailing lro? Someone there might remember the edition or just the article you need Quote Link to comment Share on other sites More sharing options...
Dano Posted March 14, 2008 Share Posted March 14, 2008 Someone had fitted an additional matrix with a fan into the passenger seat box on my landy, it seemed like quite a good idea as it was switched independently but the pipe work to it was not great, it was 15mm copper T’d into the normal matrix pipes and then run down the bulkhead and between the floor panel and chassis then elbowed into the bottom of the seat box, I though this had the potential to get snagged and cause a coolant leak so took the piping out, I may think about reconnecting in silicone pipe if I can find a better route Quote Link to comment Share on other sites More sharing options...
CR88 Posted March 14, 2008 Author Share Posted March 14, 2008 Have you tried emailing lro? Someone there might remember the edition or just the article you need Good idea!!! They know for sure, I guess... Quote Link to comment Share on other sites More sharing options...
