Bush65 Posted April 23, 2008 Share Posted April 23, 2008 A member of the Australian Land Rover Owners forum contacted Allisport in the UK and found they have a kit for fitting the VNT, as used on the International 2.8HS, to our 300Tdi engines. They have made some changes, that appear (from the photo) to make it bolt on - new exhaust, and changes to turbine and compressor. I fitted the genuine 2.8HS VNT to my 300Tdi and a bit of customisation work was required. This kit looks to solve all of that. I haven't checked with Allisport or their web site - I don't need this now, but other members here could be interested. Quote Link to comment Share on other sites More sharing options...
callum Posted April 23, 2008 Share Posted April 23, 2008 i think you need to be logged in to see that pic, so for those of you without log in... Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 23, 2008 Share Posted April 23, 2008 The price being ......... mike Quote Link to comment Share on other sites More sharing options...
Bush65 Posted April 23, 2008 Author Share Posted April 23, 2008 The price being .........mike Aus$2,385.00 (I'm assuming delivered to Australia) - don't know conversion rate from Au$ to British pound (somewhere near 2 to 1), or delivery cost. VAT is not applicable to Aus, so I assume was not included. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 23, 2008 Share Posted April 23, 2008 £1143 at today's rate from xe.com Quote Link to comment Share on other sites More sharing options...
jericho Posted April 23, 2008 Share Posted April 23, 2008 Allard motorsport in Gloucester have been offering VNT/VGT kits for 200 and 300 tdi s for some time now. Somewhere around £1000 for a full kit I believe. LINK Although Allisport are perhaps better known in landrover circles,from my small experience of them I would readily recommend Allard for alli fabrication and diesel tuning . Quote Link to comment Share on other sites More sharing options...
Bush65 Posted April 24, 2008 Author Share Posted April 24, 2008 Allard motorsport in Gloucester have been offering VNT/VGT kits for 200 and 300 tdi s for some time now.Somewhere around £1000 for a full kit I believe. LINK Although Allisport are perhaps better known in landrover circles,from my small experience of them I would readily recommend Allard for alli fabrication and diesel tuning . Thanks. Here is the link to the VNT for 300Tdi And another pic of the turbo Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 24, 2008 Share Posted April 24, 2008 Lovely! Quite pricey though! Quote Link to comment Share on other sites More sharing options...
Bush65 Posted April 24, 2008 Author Share Posted April 24, 2008 Some info from Allard, regarding setting up the VNT turbo. AMC VNT VT5 TURBOCHARGER INSTALLATION ON LAND ROVER 200 & 300 TDI Boost Gauge. It is essential when setting up the boost pressure in relation to RPM and maximum boost, to have a boost gauge installed to read boost pressure. We would recommend the following maximuim boost vs RPM curve on the 200 and 300TDI engine, for normal road use. At WOT (wide open throttle) under acceleration: 1000 RPM – 2-3 psi 1500 RPM – 5-6 psi 2000 RPM – 14-18 psi 2500 RPM – 20-24 psi 3000 RPM – 20-25 psi 3500 RPM – 20-25 psi 4000 RPM – 20-25 psi 4500 RPM – 17-20 psi For competition, the boost can be increased to 2.0 BAR (30 psi) for short bursts. Quote Link to comment Share on other sites More sharing options...
Michele Posted April 24, 2008 Share Posted April 24, 2008 I found the same link yesterday by mistake and did a quick search for this AMC VNT VT5 TURBOCHARGER but it looks like it doesn't exist in the Garrett list...??? 1 million dollar Q is I fitted the genuine 2.8HS VNT to my 300Tdi and a bit of customisation work was required How does it go then???? from my small experience of them I would readily recommend Allard for alli fabrication and diesel tuning . Didn't Andrew work at Allard before starting Allisport? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 24, 2008 Share Posted April 24, 2008 Didn't Andrew work at Allard before starting Allisport? Yes he did. but allisport is much better! Quote Link to comment Share on other sites More sharing options...
Bush65 Posted April 25, 2008 Author Share Posted April 25, 2008 ...1 million dollar Q is ...I fitted the genuine 2.8HS VNT to my 300Tdi and a bit of customisation work was required. This kit looks to solve all of that. ... How does it go then???? ... I put the VNT turbo and air to water intercooler on the 300Tdi engine at the same time that I fitted the 300Tdi into my rangie. So I didn't have any baseline to compare the 300Tdi without and with VNT turbo. It has never been on a chassis dyno, and in any case I have no faith in comparing chassis dyno results between different vehicles (too many variables). Nor do I have any faith in deriving engine figures from chassis dyno figures. I'm in the process of swapping an Isuzu 4BD1-T into the rangie (in place of the 300Tdi) and many other mods to the rangie. I have a BorgWarner R2S K16/K27.2 turbo (R2S for Regulated 2 Stage) for the 4BD1-T that, together with a tubular exhaust manifold to utilise exhaust pressure pulses, an air to water intercooler and tuning of the injection pump should give impressive performance. I have replaced the head bolts with ARP studs and expect the Isuzu head gasket and the rest of the engine to easily handle the expected 30 psi boost pressure. Now the VNT turbo is out of the rangie, I'm looking at fitting it to my disco 300Tdi, but I don't have much time to work on it at the moment. Here are some pics of my BorgWarner R2S turbo. The high pressure turbine and compressor (the small ones) are a bit larger than those used on a 300Tdi. Before the R2S came my way, I was seriously considering using the VNT turbo from my 300Tdi as the high speed turbine and compressor in a compound (2 stage) arrangement for the Isuzu. Quote Link to comment Share on other sites More sharing options...
D9OSV Posted April 25, 2008 Share Posted April 25, 2008 Andy is currently away racing at the Europeon Outbcak challenge and will be away for about 2 weeks....... @Bush65: If you are intrested give him a call when he is back, he's a really nice guy. I have heard that a VNT fitted to a 300 gives better performance than it fitted to a 2.8 as the 2.5 rev's harder? Not sure how much truth is in that though Jim Quote Link to comment Share on other sites More sharing options...
Bush65 Posted April 25, 2008 Author Share Posted April 25, 2008 Andy is currently away racing at the Europeon Outbcak challenge and will be away for about 2 weeks.......@Bush65: If you are intrested give him a call when he is back, he's a really nice guy. I have heard that a VNT fitted to a 300 gives better performance than it fitted to a 2.8 as the 2.5 rev's harder? Not sure how much truth is in that though Jim Thanks Jim. I have emailed Andy about intercoolers and knew he was at the Outback. I started this thread to inform others about VNT turbo kits for the 300Tdi, as there was a lot of interest in the thread about the VNT for TD5 engines. I already have a VNT from the 2.8HS, so don't need one of these kits. Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 25, 2008 Share Posted April 25, 2008 Andy is currently away racing at the Europeon Outbcak challenge and will be away for about 2 weeks.......@Bush65: If you are intrested give him a call when he is back, he's a really nice guy. I have heard that a VNT fitted to a 300 gives better performance than it fitted to a 2.8 as the 2.5 rev's harder? Not sure how much truth is in that though Jim Fully optimised I can believe that however every tdi I've driven feels rough and badly balanced compared to a 2.8. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted April 25, 2008 Author Share Posted April 25, 2008 Fully optimised I can believe that however every tdi I've driven feels rough and badly balanced compared to a 2.8. I seem to remember specs for the 2.8 mentioning a balance shaft. If so, they should feel better. Quote Link to comment Share on other sites More sharing options...
JST Posted August 16, 2016 Share Posted August 16, 2016 this may answer my other boost quesiton - 20-25psi on a 30tdi then? Quote Link to comment Share on other sites More sharing options...
theodorus Posted November 14, 2022 Share Posted November 14, 2022 On 4/23/2008 at 12:14 PM, callum said: i think you need to be logged in to see that pic, so for those of you without log in... Quote Link to comment Share on other sites More sharing options...
