Seth Posted April 29, 2008 Share Posted April 29, 2008 Having followed white90's excellent guide to replacing the front bearings, I still have a little play When I grab the tyre at 3.oo and 9.00 and give it a wiggle, the wheel has a little latteral movement approx 1- 2mm but when I grab the wheel at 12.00 and 6.00 and wiggle, it is rock solid. I have re checked overtightened and re torqued the hub nuts but still there is some sideways play. (not sure if wheel was solid when grabbed at 12.00 and 6.00 before I changed the bearings, but the movement is the same as before when held at 3.00 and 9.00) No doubt I replaced the wrong bearings. thanks for any help Seth Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 29, 2008 Share Posted April 29, 2008 Track rod ends are worn. Quote Link to comment Share on other sites More sharing options...
Gromit Posted April 29, 2008 Share Posted April 29, 2008 it's handy to have a helper wiggle the wheel while you peer at everything. Should be pretty easy to spot. If you can't see the movement or play, sometimes you can feel it as the 2 parts move in relation to each other Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted April 29, 2008 Share Posted April 29, 2008 Are you saying that you can move the whole wheel sideways 1-2mm in line with the axle, or that it can be rocked 1-2mm? If the whole thing can be moved 1-2mm in line with the axle when pulled at 9 and 3, but is solid at 12 and 6 then it suggests that the wheel bearing is still too loose. If the wheel can be rocked (i.e the front comes towards you and the back goes away at the same time and vice versa) when pulled/pushed at 9 and 3, then I would be looking at the Track Rod Ends- easiest to check with a helper who should be able to see the movement between the wheel and steering shafts when you rock the wheel at 9 and 3. Quote Link to comment Share on other sites More sharing options...
Seth Posted May 2, 2008 Author Share Posted May 2, 2008 Cheers people the movement is if you push the wheel edge towards the engine and then back ie at right angles to the vehicle, rather than movement in line with the vehicle ie towards the front bumper and back bumper. I will get my not so happy helper (the missus) to give me a hand this week end and have a look at the track rod ends cheers again Seth Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 2, 2008 Share Posted May 2, 2008 It was probably Les Henson's post, not White90s. credit where credit's due and all that. See if the movement disappears when the foot brake is held on - if it does, it's in the bearing. if not, look at the track rod end or the swivel pins. edit - i should stop trying to do too many things at once. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted May 2, 2008 Share Posted May 2, 2008 erm that last post doesnt make any sense, its backwards. if the bearings got play it will dissapear when you brake as the caliper will hold the hub tightly if the track rod end has play it will not dissapear when you brake as the caliper etc all moves on the swivel and therefore is affected by the track rod end... Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 2, 2008 Share Posted May 2, 2008 my bad, i was doing too many things at once! Yes, it should be the other way round, I've edited it now. Quote Link to comment Share on other sites More sharing options...
stobbie Posted May 2, 2008 Share Posted May 2, 2008 Also check the panhard rod bushes.. Quote Link to comment Share on other sites More sharing options...
Seth Posted May 3, 2008 Author Share Posted May 3, 2008 It was probably Les Henson's post, not White90s. credit where credit's due and all that. ah sry posted by white90 hard work by Les Quote Link to comment Share on other sites More sharing options...
Seth Posted May 4, 2008 Author Share Posted May 4, 2008 Missed out vital bit on my original post sry... "when brake is applied" I have no movement 12.00 6.00 but 3.00 to 9.00 I can still rock it (i.e the front comes towards you and the back goes away at the same time and vice versa). (cheers Milemaker) From the v helpful posts i am getting it's the track rod ends sigh Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted May 4, 2008 Share Posted May 4, 2008 Sounds like the top swivel housing bearing has worn to me. Is your steering a bit vague at times & tends to wander adhoc? Adrian Quote Link to comment Share on other sites More sharing options...
Seth Posted May 4, 2008 Author Share Posted May 4, 2008 Sounds like the top swivel housing bearing has worn to me. Is your steering a bit vague at times & tends to wander adhoc?Adrian As you may have guessed this is my first landy and I have had it about a month (so complete newb) so its hard to say... what I can say its not sharp like the works car but doesnt seam to drift anywhere when driven Quote Link to comment Share on other sites More sharing options...
kingrat Posted May 21, 2008 Share Posted May 21, 2008 Also look at upper and lower steering joints, and drop arm ball joint, if everything else is ok. Took some decent play out of my steering just by replacing the top joint Quote Link to comment Share on other sites More sharing options...
stobbie Posted May 22, 2008 Share Posted May 22, 2008 also look at the panhard bush Quote Link to comment Share on other sites More sharing options...
dantd5 Posted May 22, 2008 Share Posted May 22, 2008 I will check most of the below--- 1)Track Rod Ends- 2)Lower Steering Joints 3) Drop Arm Ball Joint 4)Swivel Housing Bearing 5)Steering Damper ?????? All these could have a play in it. This will test your patience but cumbersome and irritating if you have just one care at home Good luck.. I had a similar problem and the culprit was the Drop Arm plus Steering damper..... Quote Link to comment Share on other sites More sharing options...
