wkw90 Posted May 29, 2008 Share Posted May 29, 2008 Picked up a 90 last night with Mo , and on the way home rear wheel bearing went . 1 trip with the AA later I am home The bearing inner track is stuck fast to the stub axle the axle is from a disco 200 tdi . I have a RRC back axle sitting here so was thinking I could just swap the stub axle over is this possible ? Many thanks Paul Quote Link to comment Share on other sites More sharing options...
v8bertha Posted May 29, 2008 Share Posted May 29, 2008 You may be able to use it. BUT.... all stub axles are not the same! Chassis numbers for both vehicles would enable someone with MicroCAT to identify is they are the same tho. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 29, 2008 Share Posted May 29, 2008 Why not just change the axle over completely. That way you know what axle you have when it comes time to order bits. Rather than have Def stuff 1 side and RRC the other Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted May 29, 2008 Share Posted May 29, 2008 Hi Cut the old track off carefully with a grinder, if you cut it in a spiral shape till its most of the way through you should be able to split it with a chisel, then it will come off ok. Mike Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 29, 2008 Author Share Posted May 29, 2008 Why not just change the axle over completely. That way you know what axle you have when it comes time to order bits. Rather than have Def stuff 1 side and RRC the other If only things were that easy , the axle case has a bad case of wood worm Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 29, 2008 Author Share Posted May 29, 2008 HiCut the old track off carefully with a grinder, if you cut it in a spiral shape till its most of the way through you should be able to split it with a chisel, then it will come off ok. Mike Looks like thats what will have to be done , i was just being lazy Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2008 Share Posted May 29, 2008 or swap both stub axles from the RR axle onto the Disco axle & again you'll know what bits fit. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 29, 2008 Author Share Posted May 29, 2008 or swap both stub axles from the RR axle onto the Disco axle & again you'll know what bits fit. That sounds like a plan Quote Link to comment Share on other sites More sharing options...
Chunky Posted May 29, 2008 Share Posted May 29, 2008 Run a bead of weld, all the way around the stuck fast, bearing track, Wait until it is cold and it will fall out. Fit a new bearing .......done ! Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 29, 2008 Author Share Posted May 29, 2008 Run a bead of weld, all the way around the stuck fast, bearing track, Wait until it is cold and it will fall out. Fit a new bearing .......done ! Slight hitch (no welder ) Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 29, 2008 Share Posted May 29, 2008 Slight hitch - inner track friction welded to stub axle. New stub axle is about £35 IIRC Mo Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 29, 2008 Share Posted May 29, 2008 Run a bead of weld, all the way around the stuck fast, bearing track, Wait until it is cold and it will fall out. Fit a new bearing .......done ! no it wont.............. it will just shrink itself onto the stub axle ......... now, if it was the outer race in the hub, then that would be different Ian Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 30, 2008 Author Share Posted May 30, 2008 Well Mo and myself tried to fit the stub axle from the RRC on the back today and its too long for the 90 hubs . Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 30, 2008 Share Posted May 30, 2008 There are different combinations of stubs and hubs .................. use the RR hubs with the RR stubs and it should be OK............... The calipers are common and will fit all the axles. Ian Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 30, 2008 Author Share Posted May 30, 2008 There are different combinations of stubs and hubs .................. use the RR hubs with the RR stubs and it should be OK...............The calipers are common and will fit all the axles. Ian Well my good lady bless her was having a clear out and took the hubs from the RRC to the dump Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 30, 2008 Share Posted May 30, 2008 So out with the grinder at first light and see if you can get that track off then Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted May 30, 2008 Author Share Posted May 30, 2008 So out with the grinder at first light and see if you can get that track off then Mo No , done that and cocked it up So order new one Monday . Quote Link to comment Share on other sites More sharing options...
wkw90 Posted June 1, 2008 Author Share Posted June 1, 2008 Well got a RRC hub to go on the stub axle put it all together and the 24 spline half shafts don't fit in the RRC stub axle Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 1, 2008 Share Posted June 1, 2008 Not a lucky sort of person, are you Paul ? Mo Quote Link to comment Share on other sites More sharing options...
paintman Posted June 1, 2008 Share Posted June 1, 2008 no it wont.............. it will just shrink itself onto the stub axle ......... now, if it was the outer race in the hub, then that would be different Ian I've done several that way with a mig & its worked every time. The heat expands the race & the weld stops it shrinking back. But as you haven't got a mig then its out with the angle grinder. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted June 1, 2008 Share Posted June 1, 2008 I've done several that way with a mig & its worked every time. The heat expands the race & the weld stops it shrinking back. Metal alway shrinks more that it expands when subjected to high temperatures (such as welding)............... A common way to remove an outer bearing from a housing is to run a bead on mig completely around the circumference, wait for it to cool and nine times out of ten it will fall out (probably as much as 2 or 3 thou shrinkage on a large HGV / Agri outer)............................ with an inner on a shaft, run the bead around in the same way, but remove the inner race whilst it is still red hot. The weld itself will not stop shrink back. One of a good welders greatest skills is pre-empting and minimizing expansion and then shrinkage in the welded material. Ian Quote Link to comment Share on other sites More sharing options...
