Daan Posted June 5, 2008 Share Posted June 5, 2008 Yes, my battery has gone harry flatters. It currently is a Kwikfit special, and has been there since 2002. So that is a bit of a result I think and £97 buys me a new one. it is a standard discovery battery at 75 AH. Since I have fitted an electric rear winch, I found the single battery a bit lacking at times, So I was thinking of having something with a bit more electrical beans fitted, but in the same dimensions. Which one can anyone recommend. I specifically dont want to carry a second battery. Daan Quote Link to comment Share on other sites More sharing options...
smo Posted June 5, 2008 Share Posted June 5, 2008 Oddyssey make good batteries, personally i rate them waaaaaaay above optimas. Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 5, 2008 Share Posted June 5, 2008 Someone on the forum is selling red top optimas for £95, might be worth a look. Pete Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 5, 2008 Share Posted June 5, 2008 Wasn't Si at XEng selling good batts. I'm sure I've seen them on his website Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted June 5, 2008 Share Posted June 5, 2008 I have one of X-eng batteries in my 90 running the winch, Very impressed to say the least......I also have a Optima red top but thats a different story. Dave. Quote Link to comment Share on other sites More sharing options...
Escape Posted June 6, 2008 Share Posted June 6, 2008 If you have room for it, a standard battery with a bigger capacity is the most cost-efficient solution. A standard one for a Defender is 110Ah, so gives you about 50% more capacity. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted June 6, 2008 Share Posted June 6, 2008 I run a Numax battery which is what Big Si R sells. Superb abd damn good VFM Quote Link to comment Share on other sites More sharing options...
roguevogue Posted June 6, 2008 Share Posted June 6, 2008 I run a Numax battery which is what Big Si R sells. Superb abd damn good VFM I'm running 2 Very good batteries, lots of winching, all three winches together at one stage, no power supply problems at all. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted June 6, 2008 Share Posted June 6, 2008 I'm running 2 Very good batteries, lots of winching, all three winches together at one stage, no power supply problems at all. One day I too will run two Quote Link to comment Share on other sites More sharing options...
B reg 90 Posted June 6, 2008 Share Posted June 6, 2008 Daan, I am shocked that you are turning to the darkside!!! Adrian Quote Link to comment Share on other sites More sharing options...
Daan Posted June 7, 2008 Author Share Posted June 7, 2008 Wel if you read carefully, you noticed that I was talking about the rear winch being electric EP9. The front is good old PTO. The reason for this is that I can still use the rear winch when the world has turned upside down. But for the few times I use the rear winch, I dont want the weight penalty of the second battery. I am kind of thinking about the halfords option at the mo. Daan,I am shocked that you are turning to the darkside!!! Adrian Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted June 7, 2008 Share Posted June 7, 2008 To be honest the X-eng ones (Numax) are so well priced at £90 you cant go wrong........halfords ones are going to be a bit cheaper but how much? Dave. Quote Link to comment Share on other sites More sharing options...
