Guest DiscoTD4 Posted June 9, 2008 Share Posted June 9, 2008 1997 Disco TD300 anyone know if it's possible to change the output shaft seal on the steering box without removing it from the car ? Its the bottom seal for the output shaft that connects to the drop arm cheers Quote Link to comment Share on other sites More sharing options...
andyb Posted June 9, 2008 Share Posted June 9, 2008 It's much easier out on the bench. You have to get the drop arm off either way and that will be easier in a vice or using a press Quote Link to comment Share on other sites More sharing options...
Beast5680 Posted June 9, 2008 Share Posted June 9, 2008 it can be done, the hardest part is getting the drop arm off first, then it becomes fiddly and you get a wet arm, usually its a precurser to a new box but i replaced the seal in mine just over 2 years ago and its been dry since Quote Link to comment Share on other sites More sharing options...
DiscoTDi Posted June 9, 2008 Share Posted June 9, 2008 arrhhh - wet arm syndrome !! I've had a few of those recently doing various under car fluids recently - replaced axle oils, gearbox filters, engine sump pan and brake fluid, so may as well chuck in power steering fluid to complete the list thanks for the replies everyone, yes normally I'd go for the remove option and do a thorough clean and examination on the bench as suggested, but to be honest I've done so much work on her recently I'm suffering from 'overhaul fatigue' n The replies have given me enough confidence to tackle in situ first, I can always go to plan B if required Cheers everyone Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 10, 2008 Share Posted June 10, 2008 Have you tried putting a small amount of brake fluid in the PAS fluid? The brake fluid makes the rubber seal swell up a small amount and sometimes cured the leak if it isn't too bad. Les. Quote Link to comment Share on other sites More sharing options...
freeagent Posted June 10, 2008 Share Posted June 10, 2008 ^^^^Wot he said...... if its only damp rather than pouring out, you could try a splash of brake fluid in the PAS fluid.. it worked for me on my old defender 300Tdi... Quote Link to comment Share on other sites More sharing options...
DrRob Posted June 10, 2008 Share Posted June 10, 2008 Interesting hint on adding brake fluid, never heard of that one before but how much is a "splash"? An eggcup full? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 10, 2008 Share Posted June 10, 2008 Couple of capfulls is usually enough. Les. Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted June 10, 2008 Share Posted June 10, 2008 no I have'nt tried / heard that one. I'll give it a go and report back. - perhaps throw an egg in as well for good measure Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted June 10, 2008 Share Posted June 10, 2008 no I have'nt tried / heard that one. I'll give it a go and report back.- perhaps throw an egg in as well for good measure No, you only use eggs in radiators to stop leaks Ian Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted June 10, 2008 Share Posted June 10, 2008 lol Quote Link to comment Share on other sites More sharing options...
DrRob Posted June 18, 2008 Share Posted June 18, 2008 no I have'nt tried / heard that one. I'll give it a go and report back.- perhaps throw an egg in as well for good measure Did the brake fluid trick work....? I'm intrigued.... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 18, 2008 Share Posted June 18, 2008 The brake fluid usually takes a few days to have any effect. If the leak is bad, or the shaft itself is the problem, then it'll make no difference. Les. Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted June 20, 2008 Share Posted June 20, 2008 Did the brake fluid trick work....? I'm intrigued.... To be honest I've not picked up the courage to do this yet Quote Link to comment Share on other sites More sharing options...
Brasco Posted August 7, 2008 Share Posted August 7, 2008 just been trying to remove the drop arm with pas box in place on my disco 200 today... but it seems as it will be a hard task to tackle, cause i tried to remove the drop arm with a two legged puller as suggested by hayes manual but to no avail.. now i got fed up and tired drinking beer ... here in Malta presently it's like living in an oven...very high tempretures, which do not help, while you are crawling underneat the Disco... left the puller on tension, maybe overnight the drop arm will give way...but miracles don't happen anymore...do they?? tomorrow will give it an other try, cause i need to change the seals cause of the Vrt... interesting fact the hydraulic oil treatment, but in my case, the leak is a heavy one... friend of mine puchased some additive but it worked for a couple of days and the leak returned ... anyways...going to sleep...feeling my arms as if i worked out at a gym for a whole week... damn puller !!! Quote Link to comment Share on other sites More sharing options...
Chaos Posted August 7, 2008 Share Posted August 7, 2008 Interesting development, brake fluid in the steering box will make the seals swell as the rubber/fluid criteria is different. Hence the leak cure, all right on a road going vehicle. I am a Licensed aircraft engineer can I try this on a Boeing 747................. Awaiting your informative replies............... Are you flying on my aircraft...................... :lol: Quote Link to comment Share on other sites More sharing options...
stevegibbs Posted August 8, 2008 Share Posted August 8, 2008 Interesting development, brake fluid in the steering box will make the seals swell as the rubber/fluid criteria is different. Hence the leak cure, all right on a road going vehicle.I am a Licensed aircraft engineer can I try this on a Boeing 747................. Awaiting your informative replies............... Are you flying on my aircraft...................... :lol: Do you work for Quntas, doing body work? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 8, 2008 Share Posted August 8, 2008 Do you work for Quntas, doing body work? PMSL!!! Quote Link to comment Share on other sites More sharing options...
