AD90 Posted July 3, 2008 Share Posted July 3, 2008 Has anyone got a diagram showing the correct orientation for the installation of these seals? (FTC4785G) Also does anyone have experience of Britpart Stub-shafts (FTC3188) I ask as I have just spent a bit of time swearing at a Britpart rear crossmember. Thanks AD90 Quote Link to comment Share on other sites More sharing options...
western Posted July 3, 2008 Share Posted July 3, 2008 seal fits with the lips leading [facing the bearing] Quote Link to comment Share on other sites More sharing options...
v8bertha Posted July 3, 2008 Share Posted July 3, 2008 Either I've been fitting these wrongly for the past few years without any leaks and am about to make a right tit of myself or I've misunderstood Western's response... FTC4785G (Corteco?) should have a sticky uppy lip. This goes towards the stub axle. According to the printing on the actual seal it should be fit to a depth of 4mm. A cunning little trick I use when fitting these is to use the drive member as a drift... its the perfick size. Unfortunately it fits the oil seal to a depth of 6mm if you keep hitting it, so be gentle. Using the wonderous powers of Microsoft Word I have knocked up the following highly technical drawing Sorry, no idea about Britpart stub axles, but may be worth having some emery paper at the ready HTH Dan Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 3, 2008 Share Posted July 3, 2008 I do them the same as Dan, as above. Mo Quote Link to comment Share on other sites More sharing options...
white90 Posted July 3, 2008 Share Posted July 3, 2008 ditto Quote Link to comment Share on other sites More sharing options...
AD90 Posted July 3, 2008 Author Share Posted July 3, 2008 Thanks guys, I have fitted it the right way. Probably the pitting on the stub-shaft that is causing the leak, hence the question about the Britpart stub-shaft. £35+VAT as opposed to £69+VAT from LR Cheers AD90 Quote Link to comment Share on other sites More sharing options...
GBMUD Posted July 3, 2008 Share Posted July 3, 2008 Buy the Landrover one, that way, you will only have to buy once. The last Britpart one I had was so oversized it had to visit the lathe before I could fit a bearing over it. Chris Quote Link to comment Share on other sites More sharing options...
AD90 Posted July 3, 2008 Author Share Posted July 3, 2008 Thanks Chris, I have tried polishing the seal areas and fitting the seal a little deeper into the hub. Hopefully that will do the trick for now. AD90 Quote Link to comment Share on other sites More sharing options...
