ltwt1981 Posted November 13, 2008 Share Posted November 13, 2008 My brother has just got a 90, drum rear brakes G reg. I've suggested disc brakes on the rear and can get a disco axle. Will the axle casing be the same, i.e. just change the ends or is it a complete axle swap. I know probably not much in it for time but am interested. Quote Link to comment Share on other sites More sharing options...
disco_al Posted November 13, 2008 Share Posted November 13, 2008 straight swap over of the whole axle is easiest Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 13, 2008 Share Posted November 13, 2008 My brother has just got a 90, drum rear brakes G reg.I've suggested disc brakes on the rear and can get a disco axle. Will the axle casing be the same, i.e. just change the ends or is it a complete axle swap. I know probably not much in it for time but am interested. Complete axle change is fairly easy to do. I'm not sure the ends will swap over anway. Quote Link to comment Share on other sites More sharing options...
white90 Posted November 13, 2008 Share Posted November 13, 2008 ends alone leaves you without a place to bolt the calipers Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted November 13, 2008 Author Share Posted November 13, 2008 Just wondered that was all, so complete swap it is. Quote Link to comment Share on other sites More sharing options...
patch1 Posted November 13, 2008 Share Posted November 13, 2008 Dose anything need to be done with the brake system its self as the balance vales are different for drums and discs. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted November 13, 2008 Share Posted November 13, 2008 use the brake line that comes with it and join using the flexi hose on the land rover. Not sure about the brake bias stuff, all i know is the back brakes lock up on mine well before the front, which makes it interesting. Quote Link to comment Share on other sites More sharing options...
Monster Posted November 13, 2008 Share Posted November 13, 2008 straight swap over of the whole axle is easiest Hi Guys, I am planning to do the same thing. But my RR axle doesnt have any diff or drive shafts. Could i use the internals from the 90 axle? Or would there be issues with shaft length or other probs? (Complete axles are bit of a scarce item around here!) Cheers. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted November 13, 2008 Share Posted November 13, 2008 Hi Guys,I am planning to do the same thing. But my RR axle doesnt have any diff or drive shafts. Could i use the internals from the 90 axle? Or would there be issues with shaft length or other probs? (Complete axles are bit of a scarce item around here!) Cheers. you can use the diff, not sure wether the half shaft would be the right length though Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 13, 2008 Share Posted November 13, 2008 The axle tubes are all the same length. The difference comesfrom the stub and associated bits. Quote Link to comment Share on other sites More sharing options...
Monster Posted November 13, 2008 Share Posted November 13, 2008 The axle tubes are all the same length. The difference comesfrom the stub and associated bits. Do i have no choice but source axle shafts then? I thought the bolt pattern was the same for RR and 90. Maybe wrong just thought! Quote Link to comment Share on other sites More sharing options...
jack54turbo Posted November 14, 2008 Share Posted November 14, 2008 hi im not sure but i think youll also probs want to check that the replacement axle and the exixting axle have matching diff ratios on the diff's! just a thought jack Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2008 Share Posted November 14, 2008 hi im not sure but i think youll also probs want to check that the replacement axle and the exixting axle have matching diff ratios on the diff's!just a thought jack all 90/110/RR Classic/Discovery have the same ratio in the diffs 3.54:1 so swapping axles isn't a problem from the diff ratio. Quote Link to comment Share on other sites More sharing options...
gruntus Posted November 15, 2008 Share Posted November 15, 2008 Dose anything need to be done with the brake system its self as the balance vales are different for drums and discs. Hi Patch, Its a bit of a grey area in terms of braking, I asked this a while ago as I wanted disk brakes on my 1985 90 (I am still in the middle of rebuilding the project and went with a RR Clasic rear axle). Some people left the pressure reduction valve in place (at the bulkhead) to maintain the braking bias and some people removed it. Some who removed it reported the rear axle locking under heavy braking and some didn't. I am goiing to leave mine on once complete (its a rolling two year project ) and remove it if necassary. This may appear to be a bit of hit and miss however the good news is you can buy a variable pressure valve (used for kit cars etc) and tweak the pressure to suit the rear axle as needed. These were actually cheaper than I expected and could get them new for approx £20 of eBay. HTH Cheers Grant Quote Link to comment Share on other sites More sharing options...
