Badger90 Posted December 4, 2008 Share Posted December 4, 2008 if you do not fancy buying a proshaft sockit thingy.. what i done is got 3/8th drive ratchet and extention bar (about 6inch somthing like that) and 9/16th sockit.. and therr you are.. saved few bob.. bit simple idea and some may have allready foudn it out but oh well.. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 4, 2008 Share Posted December 4, 2008 Normally a socket is too big and fouls on most of the bolts. That's why the tool is so "waisted" immediately after the socket fitting. Either you have a funky socket or some funky props! Still, if it works for you good on you. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 4, 2008 Share Posted December 4, 2008 I've got the 1/2" drive version of the proper tool, but actually find the 3/8" wobble bar extension and 9/16" socket much easier... Unbolting a propshaft is one my least favourite jobs, along with oil changes. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted December 4, 2008 Author Share Posted December 4, 2008 I've got the 1/2" drive version of the proper tool, but actually find the 3/8" wobble bar extension and 9/16" socket much easier...Unbolting a propshaft is one my least favourite jobs, along with oil changes. yeah wabble exetion bar.. didnt know it had a name.. yeah propshaft are hatfully jobs.. Quote Link to comment Share on other sites More sharing options...
stravaigin Posted December 4, 2008 Share Posted December 4, 2008 i've got a propshaft tool from Diflock, thought it was well worth the money. Quote Link to comment Share on other sites More sharing options...
muddy Posted December 4, 2008 Share Posted December 4, 2008 I got a 3/8" drive, and 9/16" socket, welded them together and set too with the angle grinder. Only because i needed one right there and then otherwise i would buy one Quote Link to comment Share on other sites More sharing options...
ciderman Posted December 4, 2008 Share Posted December 4, 2008 if you do not fancy buying a proshaft sockit thingy..what i done is got 3/8th drive ratchet and extention bar (about 6inch somthing like that) and 9/16th sockit.. and therr you are.. saved few bob.. bit simple idea and some may have allready foudn it out but oh well.. Have you used the prop tool yet ? Its far better than a socket and extension , its proflied to fit between the yokes far better than any other tool ive used . Quote Link to comment Share on other sites More sharing options...
JST Posted December 5, 2008 Share Posted December 5, 2008 i go with the prop tool - brilliant bit of kit. jack a wheel up, impact wrench, spanner and prop tool - 3mins to get a prop off? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 5, 2008 Share Posted December 5, 2008 I binned that propshaft tool. Too heavy and numb IMO. It would be useful with a windy gun. I reverted back to the old tried and tested method of a ring spanner and a combination spanner. My biggest gripe on prop bolts is people who can't fit the bolts correctly and not being able to tighten or indeed undo the nut. mike Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 5, 2008 Share Posted December 5, 2008 I bought the 3/8" drive prop nut tool off difflock, it is kept in my landy after discovering it's usefulness. I have used it several times, as have friends who were reluctant to return it. I was advised to go for the 3/8" over the 1/2" drive as the 3/8 access is much easier. Pete Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 5, 2008 Share Posted December 5, 2008 I was advised to go for the 3/8" over the 1/2" drive as the 3/8 access is much easier. I think that is the mistake I made - as I only had a 1/2" drive set at the time, I bought the 1/2" tool. It is a little big and clumsy. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 5, 2008 Share Posted December 5, 2008 Has anybody tried a 1/4" drive 9/16" AF socket ? mike Quote Link to comment Share on other sites More sharing options...
Badger90 Posted December 5, 2008 Author Share Posted December 5, 2008 Has anybody tried a 1/4" drive 9/16" AF socket ?mike no.. havnt got a sockit small enough for 1/4 drive. i am thinking of getting a propshaft tool but the 9/16th sockit i use the walls are thiner then the propshaft tool.. so it fit it easy.. Quote Link to comment Share on other sites More sharing options...
Diff Posted December 5, 2008 Share Posted December 5, 2008 Has anybody tried a 1/4" drive 9/16" AF socket ?mike Yes, I have Mike. You can't get enough torque to loosen tight prop bolts with a standard length quarter drive ratchet. A bigger ratchet and adapter might shear the 1/4'' drive, so I have been using conventional spanners to loosen or tighten the bolts, and using 1/4'' drive socket to run the nuts on and off. Regards, Diff Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 5, 2008 Share Posted December 5, 2008 Yes, I have Mike. You can't get enough torque to loosen tight prop bolts with a standard length quarter drive ratchet. A bigger ratchet and adapter might shear the 1/4'' drive, so I have been using conventional spanners to loosen or tighten the bolts, and using 1/4'' drive socket to run the nuts on and off.Regards, Diff That was the way I was thinking...... mike Quote Link to comment Share on other sites More sharing options...
