Ibex94 Posted December 18, 2008 Share Posted December 18, 2008 Am rebuilding my front axle and need to retorque the swivel retaining bolts. I am therefore looking for a 14mm bihex crow foot wrench. Have looked all over but cannot find a bihex foot. Anyone out there in L/R help with this? If no joy then a spanner will need modifying. Cheers Rob Quote Link to comment Share on other sites More sharing options...
simonr Posted December 19, 2008 Share Posted December 19, 2008 I don't quite understand why you need a crows-foot wrench? I've done this before but don't own any crows foot wrenches? Si Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 20, 2008 Share Posted December 20, 2008 I just do them up mental tight. If you modify something in order to use a torque wrench, then there's a possibility that you may negate the scale on the wrench and therefore tighten the bolts incorrectly. Les. Quote Link to comment Share on other sites More sharing options...
AndyEvans Posted December 20, 2008 Share Posted December 20, 2008 and for that reason there are some maths to do. or a handy online calcultor http://www.norbar.com/Calculators/TorqueWr...70/Default.aspx Quote Link to comment Share on other sites More sharing options...
white90 Posted December 20, 2008 Share Posted December 20, 2008 B tight as Les says has always done mine no harm Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted December 20, 2008 Share Posted December 20, 2008 9/16 ring spanner and a hammer, never done mine any harm. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 21, 2008 Share Posted December 21, 2008 I think I bent my ring spanner doing mine up with a piece of tube over it, and there was Locktite in there too. I haven't had any problems, but that's not necessarily a recommendation... Quote Link to comment Share on other sites More sharing options...
treebloke Posted December 21, 2008 Share Posted December 21, 2008 Is there any difference between 14mm and 9/16", does one fit slightly better than the other?. I have always used 9/16" which just seems to fit the better of the two. Quote Link to comment Share on other sites More sharing options...
clbarclay Posted December 22, 2008 Share Posted December 22, 2008 My experiance is standard spanners tend to be about the right length that without any additional leverage they will tighten a bolt up to about the right torque. I've not needed more than a standard combination spanner on them and only double up spanners for undoing them. Try tightening up a bolt the same size with a torque wrench and then try tightening it up some more with just a spanner to get an idea how much force/leaverage is required. Quote Link to comment Share on other sites More sharing options...
