nightrider Posted December 28, 2008 Share Posted December 28, 2008 Has anyone got any pictures of there series which has been converted to power steering. Can i use a power steering box off a disco?? what steering column do i need mine is a series 3 with a 200 tdi fitted Quote Link to comment Share on other sites More sharing options...
plank22 Posted December 28, 2008 Share Posted December 28, 2008 Has anyone got any pictures of there series which has been converted to power steering. Can i use a power steering box off a disco?? what steering column do i need mine is a series 3 with a 200 tdi fitted I have done it but not got any pics at the mo. I got a steering box, column and pump off a rangie classic. Its kinda serious work cos the steering box hits the front X member so you need to cut it out and make a new one and move it forward. The front grill will also need to go forward. I dont know what a disco column is like but i think i ended up cutting it to fit anyway at the bulk head end and used the bit at the other end with the 2 UJ's that go to the PAS box. Mine had an old 3.5 v8 in it so i drilled and tapped a few holes in the block to take the pump. Quote Link to comment Share on other sites More sharing options...
patch1 Posted December 28, 2008 Share Posted December 28, 2008 Friend of mine has got PAS on his 109 S11 hybrid ( Hi Rob ) and I think he used the top part of the S11 steering column and the bottom of the rangi one, then welded them together. Mark Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 29, 2008 Share Posted December 29, 2008 defender column fits with minimal modification and mostly uses existing bolt holes in the bulkhead. Jon Quote Link to comment Share on other sites More sharing options...
plank22 Posted December 29, 2008 Share Posted December 29, 2008 oh yeh and i had coil springs at the time as wel so im not sure if the PAS box will hit any thing on the chassis, it didnt with the coils on only the front X member. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 29, 2008 Share Posted December 29, 2008 Has anyone got any pictures of there series which has been converted to power steering. Can i use a power steering box off a disco?? what steering column do i need mine is a series 3 with a 200 tdi fitted It's only been covered about 25 times already And since you asked, here's a picture of my Series which has been converted to power steering: Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted December 29, 2008 Share Posted December 29, 2008 As always John..........your truck looks the dogs b******s! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted December 30, 2008 Share Posted December 30, 2008 If you're feeling lazy, here's a complete bolt-on retro fit system Clicky Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 30, 2008 Share Posted December 30, 2008 If you're feeling lazy, here's a complete bolt-on retro fit system Clicky For the price of that system I'd be very surprised if you couldn't find a LR specialist who would do the necessary mods for you using all LR parts, or even a forumer who's in need of a bit of cash. As long as whoever's doing it can weld properly, it's not a complicated thing to do. Quote Link to comment Share on other sites More sharing options...
Reg Posted December 31, 2008 Share Posted December 31, 2008 Hi, here is one I did earlier on my S1/S111, it is a modified Disco box and steering column driven by a Ford type PS pump. The front X member was cut off and a channel steel substituted which also locates a couple of towing lugs. The box is bolted thro the chassis using doubler plates both sides and 1/2" tube inserts inside the chassis and on top. Drive is taken off Military double pulley. The drop arm fitted straight on to the series linkage, steering is light with no wander at speed using a 15" steering wheel. The seals gave up this month after dripping for 5 years, so I got a £12 rebuild kit which my local garage fitted.( I know my limits). In this conversion you can see I fitted quick release wings, using a drilled and tapped Ali angle bolted to the bulkhead with exposed bolts down the outside of the wing. The rear flange of the wing was cropped off at the bend and the wing's mounting holes were slotted to slide out. All lighting wires were routed through a quick release multiplug. Less than 8 minute job to get nice and close up to most engine compartment jobs. Remote brake servo is under wing behind a splash plate, engine is S111 as is the running gear and pedal boxes. Parabolic springs and extended shock mounts. Fiat Panda seats. Army desert sand paint which never looks dirty. Local police dont turn a hair at wide wheels, no doors and windscreen down when it gets hot. Yes it does have inertia seat belts fitted to the ex army roll bar. Quote Link to comment Share on other sites More sharing options...
