hoarebag Posted January 19, 2009 Share Posted January 19, 2009 Possibly a stupid question but what would stop you mounting a low line winch at 90deg to it's usual mounting? I.E. The feet would be on the front face of the bumber a la warn 8724. Would this work? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 19, 2009 Share Posted January 19, 2009 Possibly a stupid question but what would stop you mounting a low line winch at 90deg to it's usual mounting? I.E. The feet would be on the front face of the bumber a la warn 8724. Would this work? That's exactly how the Warn M10000 is mounted in my ARB Winch Bumper Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 20, 2009 Share Posted January 20, 2009 Yep, will be fine and is actually better from the bolts perspective. Most lowlines also allow the gearbox casing to be rotated round so the freespool is more accessible. Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted January 20, 2009 Share Posted January 20, 2009 I was thinking about this for mounting a rear winch on the rear crossmember, seems a neat soloution with minor modification, maybe a removable lower gaurd to keep the worst of the mud off and maybe a flap in the back to see the wire spooling etc Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 20, 2009 Share Posted January 20, 2009 As long as it is not a LR cross member!!! Quote Link to comment Share on other sites More sharing options...
JST Posted January 20, 2009 Share Posted January 20, 2009 RVs TDS is mounted like that with the gearbox rotated to allow the freespool to remain at the top. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 28, 2009 Share Posted January 28, 2009 Hi, I'm guessing the people who have mounted the winch like an 8274 have cut the centre section of the rear crossmember out and added a winch tray so that the winch is bolted up against a single piece of plate like the 8274. If you were keeping the crossmember* standard and having a tubed hole for the winch line to run through onto the fairlead how would you go about mounting the winch? As the Superwinch EP9 is designed so that the nuts are semi captive and the bolts go through the winch tray/plate into the winch. *When I say standard I'm making my own close to the original design but with no holes and are just getting ideas of the best way to mount the winch/design my crossmember. So if anyones got any pictures that will be great. Thanks Steve Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 28, 2009 Share Posted January 28, 2009 If I was putting a rear winch onto a rear cross member I would replace the LR cross member with a piece of 100 x 150 x 5 box. You can taper the ends to give the same LR profile. I would then drill and tube the winch mounting holes and a fairlead opening. Lastly I would add a bolt on skid plate to protect the winch from below. However, if all you want is a below floor rear winch I would do as White90 and others have done and mount the winch to a rear tank guard that is bolted into the existing LR chassis mounts and then simply cut a slot in the LR crossmember. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 29, 2009 Share Posted January 29, 2009 I would then drill and tube the winch mounting holes and a fairlead opening. So you would have long bolts going through the crossmember into the winch. I surpose the lower of the two bolts can take the fairlead as well? Steve Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 29, 2009 Share Posted January 29, 2009 Long bolts - yep. Fairlead bolts - depends on geometry but there is no reason why they can't go right through too, but from front to back so only the head is near the rope. to minimise the chance of the rope catching the head I would use dome headed bolts. You could of course save a lot of hassle and spend a small fortune on a custom made winch cross member..... Whilst I haven't mounted my rear winch to my rear cross member, I did replace the LR one with a piece of box. Cost me about £30. Pictures are HERE Quote Link to comment Share on other sites More sharing options...
white90 Posted January 29, 2009 Share Posted January 29, 2009 Mine as Bish suggests was welded onto the Southdown rear detachable tow pack. Maurice welded it up for me way back. there are two fairleads one on the winch and one on the rear cross member, if/when that needs replacing I will copy Bish's example of a rear x member and sort the winch to suit that. Quote Link to comment Share on other sites More sharing options...
