vtrdaz Posted January 23, 2009 Share Posted January 23, 2009 Morning , I'm about to do a 96,000 service on my TD5 90 and wondered what peoples thoughts were on the difflock evo range of gear oils , and whether they were worth the extra? Cheers Darren Quote Link to comment Share on other sites More sharing options...
smo Posted January 23, 2009 Share Posted January 23, 2009 I know some people swear by them but i personally dont think they can offer anything over a good quality "standard" oil - if they are so much better i'd want to knwo what they are adding to make it so? Quote Link to comment Share on other sites More sharing options...
AD90 Posted January 23, 2009 Share Posted January 23, 2009 Get yourself down to Millers Oils, I get all my lubricants & other stuff direct from them. AD90 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 24, 2009 Share Posted January 24, 2009 I'd endorse Millers enthusiastically generally, but I contacted them re R380 oil as they don't have an obvious substitute for MTF94; their advice was to use 15w/40 semi synthetic engine oil. I'm not sure whether that's good advice ( I'm not saying it's bad; I just don't know) It seems ATF isn't adequate, and it needs a synthetic gear oil around 5w20. Apart from Texaco MTF94 (the official LR recommendation which you can allegedly get from Partco, or of course LR dealers) the difflock oil and Redline MTL seem to get get good comments when you google. The Difflock oil is not cheap but then neither is Redline or a gearbox rebuild. I'm thinking I'll go for MTF94 or Evo 1 for my R380. If anyone from Millers reads this - come on, make a proper R380 oil at a sensible price please!! Nigel Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted January 24, 2009 Share Posted January 24, 2009 I'd endorse Millers enthusiastically generally, but I contacted them re R380 oil as they don't have an obvious substitute for MTF94; their advice was to use 15w/40 semi synthetic engine oil. I'm not sure whether that's good advice ( I'm not saying it's bad; I just don't know) It seems ATF isn't adequate, and it needs a synthetic gear oil around 5w20. Apart from Texaco MTF94 (the official LR recommendation which you can allegedly get from Partco, or of course LR dealers) the difflock oil and Redline MTL seem to get get good comments when you google. The Difflock oil is not cheap but then neither is Redline or a gearbox rebuild. I'm thinking I'll go for MTF94 or Evo 1 for my R380. If anyone from Millers reads this - come on, make a proper R380 oil at a sensible price please!! Nigel Yep Partco stock it, made an improvement to my LT77 over ATF, helped with the slow shift between 1st & 2nd when cold, didnt cure it completely but certainly helped. Quote Link to comment Share on other sites More sharing options...
vtrdaz Posted January 24, 2009 Author Share Posted January 24, 2009 Cheers Chaps Darren Quote Link to comment Share on other sites More sharing options...
rick Posted January 25, 2009 Share Posted January 25, 2009 <snip> and it needs a synthetic gear oil around 5w20. Apart from Texaco MTF94 (the official LR recommendation which you can allegedly get from Partco, or of course LR dealers) <snip>Nigel Nope, MTF94 is a 75w-80 MTF, which is equivalent in viscosity range to a 10W-30 engine oil. There are a stack of MTF's suitable for an R380, http://members.shaw.ca/jbarge/MTF.htm although they may have slightly different synchro characteristics and R380's can be a bit idiosyncratic in that what one gearbox likes another may not. there are a few more available than JB's list too, with Penrite now having a synthetic MTF that they claim meets MTF94 specs. In higher ambients my first choice is generally Castrol Syntrans, and most I've put onto it prefer it over almost any other lube. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 25, 2009 Share Posted January 25, 2009 I just updated my page as it was fairly out of date. If you know of other oils to add, let me know. John Quote Link to comment Share on other sites More sharing options...
tacr2man Posted January 26, 2009 Share Posted January 26, 2009 Definately worth going Redline (my choice from experience) if you are operating in extremes i.e. cold or hot or usage. That applies to eng , trans diffs . Amsoil , mobil; or other full synthetics also an improvement .JMHO Quote Link to comment Share on other sites More sharing options...
headhunter Posted January 26, 2009 Share Posted January 26, 2009 I use Redline MTL in my R380. Gives very smooth gear changes. When cold the first gear change is a little stiff, but as soon as the oil has circulated the changes are easy. I also use Redline in the transfer and overdrive gears and their Shockproof range in the diffs. So far I can't fault it and the service range is 3-4 times standard gear oils. Initially a higher investment which pays for itself over time, reducing the number of oil changes required and providing the best gear protection you can get. John Quote Link to comment Share on other sites More sharing options...
rich90 Posted January 26, 2009 Share Posted January 26, 2009 I have a feeling that the Difflock Oil is just Redline MTL in a different bottle. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted January 28, 2009 Share Posted January 28, 2009 One thing that does help cold 1st to 2nd shifts in the morning is if you have a hand throttle as fitted to FFR Defenders and others is to pull it out to the first stop and have the engine ticking over slightly quicker-it helps to align everything speed wise in the 'box better than just blipping the throttle on upshifts. Also handy for 'cruise control' on a quiet motorway Quote Link to comment Share on other sites More sharing options...
santalars Posted January 28, 2009 Share Posted January 28, 2009 I have used the originally specified ATF IID and added Titaniumdisulfide powder (Ws2). (approx 75 grams for the whole filling) It's in now since 2000 miles and the performance has improved. It's not that the gearbox is as new now but gearchanges from first to second are easier now. Also I have the feeling that the gearbox (R380) is not getting as hot anymore. Quote Link to comment Share on other sites More sharing options...
