Smokydiesel Posted February 2, 2009 Share Posted February 2, 2009 Hi all, I’m in the middle of my 2,5 NA to 200 TDi conversion. My question: can I keep the original NA- exhaust, or is it to small and do I need a TD or 200 TDI exhaust ? It would hate squeezing the engine to much and lose all that TDI-power ! I take it that the NA-exhaust will have different brackets compared to the TD or TDI chimneys.....? Thanks ! Edwin. PS I've bought that luuuvely Steve Parker downpipe-thingie.... Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 2, 2009 Share Posted February 2, 2009 you will have to butcher the two systems together, or modify a 200 tdi defender system. when we did one last year, we used part of the n/a downpipe as a sleeve, as the 200 tdi pipe is bigger, and mated the two together under the floor. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 2, 2009 Share Posted February 2, 2009 The late 300TDi exhaust is the best one to go for - full bore width and it is easier to fit as it doesn't have that transverse rear silencer that the 200TDis have. If you get the downpipe section too you can chop it down to fit onto the Steve Parker downpipe - they're only about 20 quid and it saves all the hassle and is a nice neat job. you will probably need to modify/fabricate the centre silencer bracket as it sits too far forward on the n/a exaust - I just extended the mount rearward with some angle iron. Quote Link to comment Share on other sites More sharing options...
jason110 Posted February 2, 2009 Share Posted February 2, 2009 i think steve parker do a 200tdi exhaust modified (not sure how!) to fit a 90?? oh wait - http://www.steveparkers.com/exhausts.php?P...3448538c9ab7a72 - look down the bottom, im pretty sure i got a full exhaust system for my 110. hope thats some help Quote Link to comment Share on other sites More sharing options...
JST Posted February 2, 2009 Share Posted February 2, 2009 it will work but it would be better with a larger diameter exhaust. Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2009 Share Posted February 2, 2009 when my TD was removed & the 200Tdi fitted, the complete exhaust system was retained, only recently was the downpipe swapped for a genuine 200Tdi pipe, the rest of the system is still TD, the correct 200Tdi system has different mounts with a rubber ring & pin type hangers, if you change the whole lot, you'll have to change the hangers too. Quote Link to comment Share on other sites More sharing options...
poohbear Posted February 2, 2009 Share Posted February 2, 2009 Just finishing my conversion - the Steve Parker exhaust is an excellent bit of kit, fitted within 10mins of starting! the only mod needed was to cut about 6" off the TD pipe. The instructions with the kit recommend using TD/Tdi pipe rather than petrol/NA size if I remember correctly. Have fun! D. Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted February 3, 2009 Author Share Posted February 3, 2009 Thanks all, Just ordered a complete TD-exhaust system today. As I understand it is suited for use with the 200 TDI and has the hangers sort of in the same place as my NA exhaust has them now.......I hope.... Again, thanks for the replies ! Edwin. Quote Link to comment Share on other sites More sharing options...
western Posted February 4, 2009 Share Posted February 4, 2009 Thanks all,Just ordered a complete TD-exhaust system today. As I understand it is suited for use with the 200 TDI and has the hangers sort of in the same place as my NA exhaust has them now.......I hope.... Again, thanks for the replies ! Edwin. Yes Quote Link to comment Share on other sites More sharing options...
