Rick the Spud Posted February 3, 2009 Share Posted February 3, 2009 hi all need some chunkier tyres for my Disco which i only use for 'pay and play' days so don't want to spend too much money and don't care if they hum on the road, but don't want something which looks cool but is too wide and fouls the arches and chassis on full articulation. 1. what's the best/biggest is can go without ANY fouling or arch work? 2. mates got some 750 16s from a defender 110, will they fit/work or will they look naff? 3. the tyres i've got on at the moment sort of do the job (amazing where a standard Disco will go!) but sometimes leak around the bead and get clogged with mud - is there a solution, or just fit tubes? cheers all Rick Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 3, 2009 Share Posted February 3, 2009 235-70-16 (standard size) is as big as you can go and be certain you wont catch any bodywork. 245-75-16 is a good choice (got them on my disco) and you may only need a snip off the rear edge of the back wheel arches (called a Camel cut, as its what landrover did on the Camel trophy trucks) done neatly you'd struggle to notice it. 245's will give you an extra 20mm under the diffs, and look smart without being silly. 235-85-16's will go on, but you may need to trim a bit more of the arch away.. Lifting the suspension don't really help much as the problems are caused by the length of the arch, not the height... 7.50x16's will go on, but they are not ideal on a standard 7" disco rim, and will look a bit weedy... Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted February 3, 2009 Share Posted February 3, 2009 This is my disco on 7.50 R 16's that I picked up on ebay for reasonable money. I've been very pleased with them so far, they're Recip Trail. My truck has a 2" lift and I had to trim the arches a little. Looks very cool tho Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 3, 2009 Share Posted February 3, 2009 ....and heres mine on 245/75 r16 general grabber AT2s... Quote Link to comment Share on other sites More sharing options...
Rick the Spud Posted February 4, 2009 Author Share Posted February 4, 2009 cheers guys. looking good. freeagent - do they not touch on full articulation? they're looking a bit close on the flat! Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted February 6, 2009 Share Posted February 6, 2009 i had 265 75 16s on mine and they were too big for the arches, they were insa turbo spaecial tracks, hummed like hell on the road but were awesome were it counted, defo recomend them Quote Link to comment Share on other sites More sharing options...
Thys Posted February 7, 2009 Share Posted February 7, 2009 i had 265 75 16s on mine and they were too big for the arches, they were insa turbo spaecial tracks, hummed like hell on the road but were awesome were it counted, defo recomend them i went to 245/70/16, the lift was a minor 7,5 mm, but the extra width from the standard 205/80/16's gave a good improvement, the wheel arches are not affected, only had to do a small adjustment on the steering stoppers. The steel LR rim my Disco has is a 7J, and the tyre manufacturer's specification call for a minimum of 7J. Quote Link to comment Share on other sites More sharing options...
Dunc Posted February 7, 2009 Share Posted February 7, 2009 You simply can't post enough pictures of your Disco. Looks ace! Quote Link to comment Share on other sites More sharing options...
bluespanner Posted February 7, 2009 Share Posted February 7, 2009 How do these tall tyres affect your gearing, guys? I have a disco R380 in my truck, and run 265/75R16s. I never use top.... Quote Link to comment Share on other sites More sharing options...
Dunc Posted February 7, 2009 Share Posted February 7, 2009 I have a disco R380 in my truck, and run 265/75R16s. I never use top.... Bloody hell! Think we need a photo of it on those tyres, just for reference you understand... Quote Link to comment Share on other sites More sharing options...
Discovan300tdi Posted February 7, 2009 Share Posted February 7, 2009 Ive got 7.50 r 16s on my disco on wolf rims not lifted but heavy duty range rover front springs all round now so thats given it a bit of a lift and they dont catch on full articulation and the obligatory camel cut Quote Link to comment Share on other sites More sharing options...
mr.t Posted February 11, 2009 Share Posted February 11, 2009 A bit of info on tyre choices.... I have just bought BFG MT 245/75 and had them fitted to my V8 - No lift. (£632 for 5 fitted and balanced...phew) Apart from lock stop on one side.... I found that the tyre caught the inside edge of the front bumper... I do have sag on that side which an upcoming 2" lift will sort. My point is, If your suspension is tired, you may experience a rub on the front bumper. (I have removed the valance so therefore just trimmed all the return edge off the front bumper in front of the wheel.. this edge is now about 5mm thick.. and i also pulled the bumper bracket out a bit) I did the camel cut before fitting so don't know if the rear would have been OK or not... Cheers M Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 11, 2009 Share Posted February 11, 2009 cheers guys.looking good. freeagent - do they not touch on full articulation? they're looking a bit close on the flat! No, we've had each wheel up a ramp until it hit the bumpstops and no contact now... We did a small camel cut on the rear arch, and adjusted the steering lock stops slightly as the tyres just touched the radius arms on full lock... Landrover build tollerences are so mad that what fits OK on one disco, will not work at all on another!! Quote Link to comment Share on other sites More sharing options...
mr.t Posted February 12, 2009 Share Posted February 12, 2009 Bumper and Arch mods.... as described... Quote Link to comment Share on other sites More sharing options...
Rick the Spud Posted February 12, 2009 Author Share Posted February 12, 2009 wow all u guy's tyres are looking seriously close to the arches, i can't believe they don't touch! front bumper and valance not an issue - valance went bye bye during the first session of 4x4ing, and the sides of the bumper have rusted away! Quote Link to comment Share on other sites More sharing options...
mr.t Posted February 12, 2009 Share Posted February 12, 2009 My god.. you have the dreaded plastic rust!! Keep it away from Japanese 4x4's! Quote Link to comment Share on other sites More sharing options...
q-rover Posted February 13, 2009 Share Posted February 13, 2009 A bit of info on tyre choices....I have just bought BFG MT 245/75 and had them fitted to my V8 - No lift. (£632 for 5 fitted and balanced...phew) Apart from lock stop on one side.... I found that the tyre caught the inside edge of the front bumper... I do have sag on that side which an upcoming 2" lift will sort. My point is, If your suspension is tired, you may experience a rub on the front bumper. (I have removed the valance so therefore just trimmed all the return edge off the front bumper in front of the wheel.. this edge is now about 5mm thick.. and i also pulled the bumper bracket out a bit) I did the camel cut before fitting so don't know if the rear would have been OK or not... Cheers M Personally I would only fit a 1" lift if you already have bought your tyres. A 2" lift will give room to 7.50x16, 235.85x16, 265.75x16 tyres, so may leave a bit too much 'air' in the wheelarches to fill with just 245.75x16. Quote Link to comment Share on other sites More sharing options...
Dunc Posted February 13, 2009 Share Posted February 13, 2009 Me like. Quote Link to comment Share on other sites More sharing options...
mr.t Posted February 13, 2009 Share Posted February 13, 2009 Re: 2" lift. Yes I see your point on the lift height and tyre size... I thought long and hard about 1" or 2" and went with 2" to give extra clearance for the LPG tanks... Spacers may help with the aesthetics...if they don't I may be swapping the springs for 1" 'ers! ...at least we willl al learn from my expense!! M BTW, this is the look I am currently aspiring too!! B) Quote Link to comment Share on other sites More sharing options...
Mark Posted February 13, 2009 Share Posted February 13, 2009 245/75 with ~40mm lift: Quote Link to comment Share on other sites More sharing options...
nicks90 Posted February 13, 2009 Share Posted February 13, 2009 a lift wont stop the tyres catching on wheelarches, bumpers etc - unless the lift springs are soooo stiff it prevents the axle from going up far enough to touch the bumpstops. if the tyres catch on things, you only really have 2 choices... cut the offending bits off or fit extended bump stops. Quote Link to comment Share on other sites More sharing options...
daveyboy300tdi Posted February 13, 2009 Share Posted February 13, 2009 I recenty fitted 265/75/16's to my disco, insa turbo special tracks. Here's a few pics, i had to do lots of trimming and it still needs more... I did tong @ bradford on my current setup and I had the most extreme articulation I could hope for, they didn't catch much. Where they caught I will take off. I'm in the process of doing an extended arch conversion, if I wern't I would just take off where they caught. Quote Link to comment Share on other sites More sharing options...
Rick the Spud Posted February 14, 2009 Author Share Posted February 14, 2009 My god.. you have the dreaded plastic rust!! Keep it away from Japanese 4x4's! i meant the metal bumper under the plastic corners, numpty boy! Quote Link to comment Share on other sites More sharing options...
Dunc Posted February 15, 2009 Share Posted February 15, 2009 Have you got any lift on it Davey? Quote Link to comment Share on other sites More sharing options...
Rick the Spud Posted March 11, 2009 Author Share Posted March 11, 2009 what's a good size to go for to give extra height, but not silly wide! Quote Link to comment Share on other sites More sharing options...
