Phill B Posted March 8, 2009 Share Posted March 8, 2009 The Gearbox in my 1980 109 has a filler cap on the top held in place by a springy steel thing. 95117637 B I just bought one off eblag for 99p (seriously), but it has a small metal plate/plug where my filler cap would be. The serial is on a plate on the bell housing and showing as a rebuilt unit. But the Bell housing is off a Series 2 as it has the opening at the side for the clutch. So is it a Suffix D? If so, what Suffix is the one fitted to my 109 Quote Link to comment Share on other sites More sharing options...
SeriousIIa Posted March 8, 2009 Share Posted March 8, 2009 Phil take a look at the right side of the gearbox: There is the gearbox number with suffix number stamped. In this way you should be able to identify it. Quote Link to comment Share on other sites More sharing options...
Phill B Posted March 8, 2009 Author Share Posted March 8, 2009 Just gone over it with a fine tooth comb and can't see a serial number anywhere ion the box at all. Only thing stamped on it is 'F' Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 8, 2009 Share Posted March 8, 2009 The gearbox number is actually on the transfer box. Left edge of your picture (where the 'F' is), but further down. Les. Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 8, 2009 Share Posted March 8, 2009 The gearbox is a Rover reconditioned unit (Factory rebuild Unit), So could be from any year!! However as its "Rover" I would have said it was up to 1970, as after that it would have been labeled "British Leyland" Quote Link to comment Share on other sites More sharing options...
Phill B Posted March 8, 2009 Author Share Posted March 8, 2009 No, no serial anywhere on any face. Odd. So really this box is useless to me if its that old. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted March 9, 2009 Share Posted March 9, 2009 Heavily modified Series body, RRC chassis, 5.3 V12 engine.......its like nothing on earth....projected speed = 156mph...........Project "why the hell did i start this" coming soon!. Sorry thread hijack! Sounds an interesting project, is there a build thread for it or any more info? What tranny are you planning on using? Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted March 9, 2009 Share Posted March 9, 2009 I've just dismantled a gearbox with the same mark on it and mine was a real Series 11a Suffix F box - with no synchro on 1st and second. As Series 11 boxes go its supposed to be as strong as they come which no doubt explains why the layshaft had snapped. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 10, 2009 Share Posted March 10, 2009 No, no serial anywhere on any face. Odd.So really this box is useless to me if its that old. The advice I had from the Series 2 Club Forum is that ALL Factory Reconditioned boxes have the original number ground out by the factory, as they were rebuilt to whatever was the current (latest) specification. I can't comment on the age of the reconditioning (IE when it was done), I'm just explaining the 'lost' serial number. HTH Quote Link to comment Share on other sites More sharing options...
Phill B Posted March 10, 2009 Author Share Posted March 10, 2009 The advice I had from the Series 2 Club Forum is that ALL Factory Reconditioned boxes have the original number ground out by the factory, as they were rebuilt to whatever was the current (latest) specification.I can't comment on the age of the reconditioning (IE when it was done), I'm just explaining the 'lost' serial number. HTH That's interesting and would explain the lack of any ID at all. I was beginning to thing I had the first ever LR gearbox So what about the serial 600917? Werent all Suffix D boxes 600XXX? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 11, 2009 Share Posted March 11, 2009 ...So what about the serial 600917? Weren't all Suffix D boxes 600XXX? Don't know. You will have to ask in the S2C Forum yourself - if no-one else here knows. The main S2C Forum is open to non-members. You can add pictures to your posts there. Just to state the bleedin' obvious; don't totally forget that if the bell housing is a separate item to the box, it's possible that the bell housing you have wasn't originally associated with the gearbox. HTH Quote Link to comment Share on other sites More sharing options...
Phill B Posted March 11, 2009 Author Share Posted March 11, 2009 Cheers Dave. I did know about the bell housing but thanks anyway. I'll try the S2 guys when I get home from work. Thanks for your reply Dave, it's much appreciated. Quote Link to comment Share on other sites More sharing options...
