dicsosfa Posted March 31, 2009 Share Posted March 31, 2009 hi to everyone just a couple of questions on behalf of a mate, 1) is a transfer box from a disco (200/300) a direct fit on to a 1991 (h) 200 tdi defender if not what's involved i.e linkages/speedo and can i just swap the bits from one to the other ? 2) are the injector pumps the same on a 90 and a disco ? any help welcome Roy Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted April 1, 2009 Share Posted April 1, 2009 i've just fitted a disco box the only thing that may be diffrent is the difflock linkage but it was just a case of swaping about to get it to work the pump will fit Quote Link to comment Share on other sites More sharing options...
DivParts Posted April 1, 2009 Share Posted April 1, 2009 Yes only the ratio's are different and yes you must tweak the link's because the tunnel of your def is smaller. Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2009 Share Posted April 1, 2009 200Tdi injection pumps are the same. Quote Link to comment Share on other sites More sharing options...
dicsosfa Posted April 2, 2009 Author Share Posted April 2, 2009 Hi thanks to all that replied to my question, also will he have to use the 90's speedo drive or will the disco's be ok as he is worried the speedo won't read correct thanks Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted April 2, 2009 Share Posted April 2, 2009 i use the 90 one as the speedo is taken off the final shaft of the transfer box so only tyre size will make a diffrence Quote Link to comment Share on other sites More sharing options...
dave88sw Posted April 3, 2009 Share Posted April 3, 2009 the handbrake cable bracket was in a different place but you can just use the disco bracket and bolt the defender cable in it, much less hassle because the bolts holes werent there on the disco box for the defender bracket. Otherwise straight bolt on. Dave Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted April 3, 2009 Share Posted April 3, 2009 If the tail housing was swapped from the defender T/B to the Disco one then a standard defender handbrake setup can be used Quote Link to comment Share on other sites More sharing options...
dave88sw Posted April 3, 2009 Share Posted April 3, 2009 but much simpler to reroute the cable . Youre right but this was the easiest way to do it and it works fine for us. Dave Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted April 3, 2009 Share Posted April 3, 2009 yes i moved the cable seems fine so far Quote Link to comment Share on other sites More sharing options...
