forkrentfitter Posted June 6, 2009 Share Posted June 6, 2009 HI,I HAVE A PROBLEM WITH A TD5 90,PARKED OUTSIDE A SHOP,NEXT TO AN ATM MACHINE,CAME OUT,UNLOCKED VIA REMOTE,TURN KEY,NO DASH LIGHTS,NOTHING.THIS IS NOT MY CAR BUT A MATES,HAVE CHECKED UNDER SEAT FUSES,ALL OK.ANY SUGGESTIONS WHERE TO GO NEXT,CHRIS. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 move it away from the ATM & try again. possibly RF interfernce from the ATM machine Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 6, 2009 Share Posted June 6, 2009 No dash lights at all indicates a power issue surely? The immobiliser doesnt cut power to the dash etc, so even if it was an immo issue they dash would still light up like normal. Check the earths and battery condition. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 IIRC theres a fuse box in the engine bay on Td5's. Quote Link to comment Share on other sites More sharing options...
smo Posted June 6, 2009 Share Posted June 6, 2009 Fuse boxes are in the centre in front of the gearstick below dash, and under the drivers seat with the ECU, battery is under the passenger side. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 6, 2009 Share Posted June 6, 2009 No fuses in the engine bay. Les. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 so why does the LR RAVE manuals for the Defender Td5 electrical section show this engine bay fuse box ?? Quote Link to comment Share on other sites More sharing options...
smo Posted June 6, 2009 Share Posted June 6, 2009 No idea Ralph but i can assure you that fuse box is under the drivers seat with the ECU. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 No idea Ralph but i can assure you that fuse box is under the drivers seat with the ECU. got it sussed now, it's only called the engine compartment fuse box but actually lives under the drivers seat, what a dumb idea. Quote Link to comment Share on other sites More sharing options...
QTdarren Posted June 6, 2009 Share Posted June 6, 2009 check the main power conection on the under seat fuse box , as for what ever reason they have a habit of coming loose, ive done a few of these. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted June 7, 2009 Author Share Posted June 7, 2009 thanks for the reply,s.the vehicle lights work,but no dash lights,battery power is good,does not have a feed to the ignition,does that feed come from the ecu once immobiliser is disarmed? Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2009 Share Posted June 7, 2009 refer to the 2 atachments above, I think it will answer your question. Quote Link to comment Share on other sites More sharing options...
yella 90 Posted June 7, 2009 Share Posted June 7, 2009 you have a direct feed coming up from the main fuse box which in turn powers up your ignition,dash lights and bulkhead fuse box, which then after the ecu fuse ( located on bulkhead fuses ) powers the ecu up are you getting a fuel pump ?? have you checked the main relay situated under the drivers seat ? if its immobalised you will have dash lights but it wont crank, or some will crank but not fire dan Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted June 7, 2009 Author Share Posted June 7, 2009 getting somewhere now,seems the ignition lock assy is u/s,key feels sloppy,even the unused spare,managed to get dash lights by moving key around slowly,not good when truck has only done 30k miles! but it is an 03 truck.have a feeling ign is same as 300 tdi,can any one confirm please,chris. Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2009 Share Posted June 7, 2009 refer to my reply to your part number question, in the 'request for part numbers' forum Quote Link to comment Share on other sites More sharing options...
yella 90 Posted June 7, 2009 Share Posted June 7, 2009 yes the ignition is the same as a late 300tdi IIRC Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted June 10, 2009 Author Share Posted June 10, 2009 thanks to all who offered advice,turns out the actual switch contacts had fallen apart,all sorted now. Quote Link to comment Share on other sites More sharing options...
