adam300Tdi90 Posted July 25, 2009 Share Posted July 25, 2009 Besides brute force and ignorance (which i've tried and tried again) how on earth do you get the old a frame ball joint out?!? I've tried pressing it and got up to 6tonnes of pressure (nothing), I've also tried heating the surrounding a-frame with oxy/acetalene. Theres got to be another way!!! Please help, I keep running into brick walls like this doing my rebuild! Quote Link to comment Share on other sites More sharing options...
cieranc Posted July 25, 2009 Share Posted July 25, 2009 Mate if you've got the use of gas and a press it MUST come out! I held mine in the vice and knocked it out with a hammer and drift after warming the carrier with the gas. Just get the carrier red hot right around it, it'll give in eventually. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 25, 2009 Share Posted July 25, 2009 Silly question (I hope) - but you did cut the two tabs off the joint you are trying to press out - i.e. you are pressing one side on the joint and the other side on the carrier bracket and not on the body of the joint? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 25, 2009 Share Posted July 25, 2009 First time I tried to press an old ball joint out I forgot to cut the tabs off - felt kinda stupid when I realised Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 25, 2009 Share Posted July 25, 2009 Me too - I think most people do it but usually only once! Quote Link to comment Share on other sites More sharing options...
101sean Posted July 25, 2009 Share Posted July 25, 2009 The one I had changed a year or so ago took 30T to shift but that was after I'd tried beating out resulting in it tipping slightly Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 25, 2009 Share Posted July 25, 2009 I don't have a press, so I drilled mine out. Took a while but then I wasn't in a rush. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 25, 2009 Share Posted July 25, 2009 i got mine out with mild heating and big old club hammer. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted July 25, 2009 Share Posted July 25, 2009 Have plans on changing the A frame on mine but these stories keeps me off the task One day I might have the patience to get it done... Quote Link to comment Share on other sites More sharing options...
101sean Posted July 26, 2009 Share Posted July 26, 2009 Getting the carrier off is easy enough, just need a mate with a press or hand some beer tokens to a garage. Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted July 28, 2009 Author Share Posted July 28, 2009 thanks everyone, the guys that run the workshop next to mine have a press but it's 'only' rated to 10 tons, i went away and left it for few days. i must admit the first time i was silly enough to not cut away part of the tabs so there was something to press against, but i did realise a good few hours before posting here! i sqirted the top side with wd40 and took a brave pill. the press got up to 9.5 tons on the dial and i thought it wasn't gonna budge, then i pressed it once more and BANG! hurrah! i'm now wondering, how do I press in the new one?! don't wanna pay any one, or damage the new one...! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 28, 2009 Share Posted July 28, 2009 Use the 2 M8 bolts to align it, then a large socket/suitable tubing over tapered end and then press it in. Les. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 28, 2009 Share Posted July 28, 2009 I fitted mine with copper ease. probably not reccomended but it took a fair bit of pressing and hasn't gone anywhere in 6 months Quote Link to comment Share on other sites More sharing options...
Allan Soffientini Posted July 28, 2009 Share Posted July 28, 2009 A mate pressed the ball joint out of my 90 using a 20 t press and was an hard job. Impressed to read about people doing this work only with heat , vice and hammer; perhaps mine was very hard due to old age and a bit of rust. Quote Link to comment Share on other sites More sharing options...
