RustyNissanPrairie Posted August 5, 2009 Share Posted August 5, 2009 I have the (not too) shiny black arch spats-is it possible to paint them? and what plasticiser would you use? Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2009 Share Posted August 5, 2009 if you want to keep them black, just use normal boot polish & buff them up. Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted August 5, 2009 Share Posted August 5, 2009 Hi Not sure if this helps but i painted my 90 with sythetic enammal and i spilt some on the plastic arch Lets just say nothing in this world will remove it - tried petrol, nail varnish remover cellose thinners etc Bearing this in mind i would say you could just paint them with sythetic enammal and i am sure it will never come off Hope this helps Chris Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted August 5, 2009 Author Share Posted August 5, 2009 if you want to keep them black, just use normal boot polish & buff them up. Thinking of painting them white to suit the rest of the 110. I have a few small specks of paint on them from painting the lanny roof and it does stick the s$%t to a blanket but im wondering about when the full spat is painted and flexed at any point-boviously dont want it splitting or cracking. Quote Link to comment Share on other sites More sharing options...
kingrat Posted August 6, 2009 Share Posted August 6, 2009 WD-40 work well as a plastic shiner, just spray on and ignore it Quote Link to comment Share on other sites More sharing options...
wozza35 Posted August 6, 2009 Share Posted August 6, 2009 Get some plastic primer and it should be ok Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted August 6, 2009 Share Posted August 6, 2009 When I painted the mat black spats blue on my old 110, I just used cellulose top coat with no primer at all. Never cracked or peeled, last time I saw it about 5 years ago they were still good after about 12 years of abuse. I don't think the white would cover black without some primer though. Quote Link to comment Share on other sites More sharing options...
ChrisM_110 Posted August 6, 2009 Share Posted August 6, 2009 Halfords plastic primer usually meant for barried nova and saxo interiors works very well, nice and flexible too. I did mine with plastic primer and some cheap black acrylic. Quote Link to comment Share on other sites More sharing options...
m0bcg Posted August 8, 2009 Share Posted August 8, 2009 this is what you want . plasticare trim dye http://cgi.ebay.co.uk/Plasticare-Trim-Dye-...id=p3286.c0.m14 i have just used some today to black my wheel arch extensions and the door mirrors , the front light surrounds, the grille , rear fog and reverse light covers and door handles . great stuff, just put it on with a cotton cloth and rub it on there . any residue you get onto the paintwork you can just wipe off using thinners or spirit wipe . need vinyl gloves when putting it on . the bottle it comes in is not that big, just 150mm tall and 60mm wide , you just dab some of the fluid onto the cloth a few times so its nice and wet and then wipe over the plastic and you will see the rest . this stuff is coloured black and is a little like thin paint , but is a plastic dye , it isnt like the other junk you can buy which is merely silicone or other clear liquid . i buffed my landy paint last week and ended up with all the plastic turned a greyish white colur due to the rubbing compound being sprayed all over it whilst i was running the buffer over the body . i did have some fluid that they use on wheels and plastic trim , which i initially cleaned the wheel arch extensions with but they have gone light grey again in the week, so this time i have blacked them with this dye and it works great . i dont really care what is actually in the bottle, because it worked a treat and was easy to do . i only found it by chance after doing a search on ebay . Quote Link to comment Share on other sites More sharing options...
