sweety Posted August 30, 2009 Share Posted August 30, 2009 Hi can I ask what ACE is ? I'm sure it's something to do with the handling (am I right) will it cause me any probs when going off road. I do some green laning from muddy lanes in Northumberland to rocky lanes in the Yorkshire Dales & hopefully more lanes in the Lakes Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 30, 2009 Share Posted August 30, 2009 Active Cornering Enhancement - should tell you how it works in the book but yes - a handling aid basically hydraulically controlled anti roll bars Quote Link to comment Share on other sites More sharing options...
Briandisco Posted August 30, 2009 Share Posted August 30, 2009 Presumably not that much help off-road? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 30, 2009 Share Posted August 30, 2009 only works over a certain speed I believe. Quote Link to comment Share on other sites More sharing options...
sweety Posted August 30, 2009 Author Share Posted August 30, 2009 Thanks for that if they go wrong can you just fit a standart set up by replacing the anti roll bar ? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 31, 2009 Share Posted August 31, 2009 I guess so - not sure. I think it is supposed to disengage off road so in theory should be better than conventional anti roll bars over rough terrain. No idea about the reality though. (Actually that isn't entirely true - the reality is its another load of complicated sh&4e to go wrong on a vehicle which in some cases is now 10yrs old...) Quote Link to comment Share on other sites More sharing options...
sweety Posted August 31, 2009 Author Share Posted August 31, 2009 Thanks BogMonster for the info it's just the one i'm looking at getting I think has ACE fitted with alot of other toys Quote Link to comment Share on other sites More sharing options...
nicks90 Posted September 1, 2009 Share Posted September 1, 2009 yep - ACE is ace, when it doesnt leak or the pump fails. Then its rubbish cos it'll cost you an arm and a leg to fix. offroad it is better than a standard arb equiped disco, as under 10mph it disengages meaning you basically have no arb assistance. Quote Link to comment Share on other sites More sharing options...
q-rover Posted September 1, 2009 Share Posted September 1, 2009 It is good, I have a friend that we go on trips together with quite often, and he has a DII with ACE. On open roads he finds it difficult to keep up with me if I use the V8 a bit, but get to the twisties, and there is no hope of me keeping up with him. Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted September 1, 2009 Share Posted September 1, 2009 ACE is GREAT - makes the D2 handle the bends like nothing before it and then flex off road as good as an early Disco (which would fall over if you drove it on the road like an ACE equipt D2). The 5 seat GS has ACE, but coil springs all round - perfect combo. The only down side is when you drive over a tree using that great off road peformance and rip the ACE valve block off - £1000 repair bill time. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted September 1, 2009 Share Posted September 1, 2009 if you are thinking of buying a disco with ACE check the condition of the pipes if they are very rusty then make sure the price is right as thev are VV expensive £5-600 a set plus fitting Quote Link to comment Share on other sites More sharing options...
sweety Posted September 1, 2009 Author Share Posted September 1, 2009 if you are thinking of buying a disco with ACE check the condition of the pipes if they are very rusty then make sure the price is right as thev are VV expensive £5-600 a set plus fitting Thanks guy's as this has helped me alot in this strange (to me) world of LR Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 1, 2009 Share Posted September 1, 2009 if you are thinking of buying a disco with ACE check the condition of the pipes if they are very rusty then make sure the price is right as thev are VV expensive £5-600 a set plus fitting Yikes! That I didn't know - must be a market for non genuine ones there!! Quote Link to comment Share on other sites More sharing options...
nicks90 Posted September 2, 2009 Share Posted September 2, 2009 thats dealer prices though - as there is a set procedure and equipment for filling and bleeding the ACE system. some LR specialists now have the equipment and charge significantly less. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted September 2, 2009 Share Posted September 2, 2009 thats dealer prices though - as there is a set procedure and equipment for filling and bleeding the ACE system. some LR specialists now have the equipment and charge significantly less. and you can use a nanocom to bleed the system Quote Link to comment Share on other sites More sharing options...
nicks90 Posted September 3, 2009 Share Posted September 3, 2009 cool - thats very handy to know. any instructions just for future reference and for the tech arhive? Its worth buying a nanocom just for that if you have a leaky ACE unit, save a fortune by DIY the fault. Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted September 3, 2009 Share Posted September 3, 2009 I was told when I had mine done that the instructions on bleeding and setting up the system run to 14 pages in the manual! I think mine was the fisrt one that Brooklyn 4x4 had done at the time and it took them something like 3 hours to bleed and setup. Mind you, that's why it now gets serviced at West 4x4 Quote Link to comment Share on other sites More sharing options...
MartinK Posted September 7, 2009 Share Posted September 7, 2009 I bought my Disco new in 2002, and it's now done 155000 miles. The ACE system has given me 3 problems: 1. The upper accelerometer failed at ~3 years ~60k miles (it's above the rear view mirror in the plastic pod). 2. The upper accelerometer failed again after ~6 years (125k miles) 3. June 2009, the pipes in front of the block (attached to chassis under drivers seat) corroded thru (and the car was waxoyled). I had a quote to replace the lot, and it was over £600 (from an independant whose prices are normally good). The system has now been removed. Quite a big job. The pump is driven by the aux drive belt, so that needs replaced with an idler wheel (also got the aux drive belt replaced at the same time). Also the front anti-roll bar is replaced, and the "brain" is reprogrammed to tell it it's not got ACE (i.e. an "S" rather than a "GS". Total cost £380. After 2000 miles, and a few months I don't miss the ACE system. There's a little bit of body roll if you throw her round a roundabout. Off road I can't tell the difference. Most of my milage is on the A9 and often with a trailer, and any difference is negligable... Less to go wrong now... Quote Link to comment Share on other sites More sharing options...
MartinK Posted September 9, 2009 Share Posted September 9, 2009 I was thinking about this again. My vehicle is a 5-seat GS model (2002, and has coil springs all round. It did have ACE originally but I took it off as above ^^^ The results are fine. I do remember driving an air-suspended Disco without ACE, and it did seem to roll a bit more in corners... Just a thought - maybe ACE is more of a requirement when Air Suspension is fitted? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 9, 2009 Share Posted September 9, 2009 I don't know but I agree that the std SLS vehicles actually handle worse than coil spring vehicles having driven coil only, SLS only, and SLS + ACE. Back end doesn't feel stable just with the air springs. Quote Link to comment Share on other sites More sharing options...
