2drdan Posted April 27, 2006 Share Posted April 27, 2006 Has anyone got or fitted a 200 Tdi into a RR classic? I thought at one stage LR fitted these to the later classics (mines a 1980 2dr) so there would be some factory parts used to fit it.......? At the moment I'm most interested in the engine mounting (as from other posts and the help I've got an idea of the gearbox fitting etc..) Thanks. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 27, 2006 Share Posted April 27, 2006 Pretty certain the 200TDi (and possibly the 300TDi?) were factory fitted to the classic, and available as official conversions too. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted April 27, 2006 Share Posted April 27, 2006 I've got a 200 tdi rangy, not a factory one though, the engine mounts had been home made by whoever done the conversion Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2006 Share Posted April 27, 2006 Your correct in believing LR factory built 200 & 300Tdi RR Classic's from VIN JA610294, These engines replaced the 2.4 & 2.5 VM diesels. Quote Link to comment Share on other sites More sharing options...
2drdan Posted April 27, 2006 Author Share Posted April 27, 2006 Cheers chaps, thanks for the piccy landrover598, I am going for a set from Motor and Diesel Engineering that are supplied with their own bolt on jig to get them tacked in place before seam welding. on with the job then i guess..! Cheers. B) Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 28, 2006 Share Posted April 28, 2006 God drives a 200Tdi Range Rover and so do I Quote Link to comment Share on other sites More sharing options...
SHAVED_GORILLA Posted April 28, 2006 Share Posted April 28, 2006 God drives a 200Tdi Range Rover and so do I Yeah but gods dad drives an Isuzu 2.8tdi converted Rangie. SG Quote Link to comment Share on other sites More sharing options...
MarkieB Posted April 29, 2006 Share Posted April 29, 2006 That's the reason everyone's choking on the particulate emissions up there then Quote Link to comment Share on other sites More sharing options...
SHAVED_GORILLA Posted April 29, 2006 Share Posted April 29, 2006 Ah well keeps the weather warmer SG Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 30, 2006 Share Posted April 30, 2006 Yeah but gods dad drives an Isuzu 2.8tdi converted Rangie. SG I thought that was what Jesus had in his daily driver. He drives a 70 series 'cruiser at the weekends Quote Link to comment Share on other sites More sharing options...
SHAVED_GORILLA Posted May 1, 2006 Share Posted May 1, 2006 I thought that was what Jesus had in his daily driver. He drives a 70 series 'cruiser at the weekends He learn't everything he knows off his good old grandad. Quote Link to comment Share on other sites More sharing options...
Phil.Mcavity Posted May 1, 2006 Share Posted May 1, 2006 Has anyone got or fitted a 200 Tdi into a RR classic? I thought at one stage LR fitted these to the later classics (mines a 1980 2dr) so there would be some factory parts used to fit it.......? At the moment I'm most interested in the engine mounting (as from other posts and the help I've got an idea of the gearbox fitting etc..) Thanks. Just done this conversion in my bobtail, its awsome!!! just watch the rear of the rocker cover fouling on the bulkhead, mines a bit tight! Used disco mounts seam welded on, very easy conversion took a whole day to do including gearbox aswell Quote Link to comment Share on other sites More sharing options...
2drdan Posted May 2, 2006 Author Share Posted May 2, 2006 Just done this conversion in my bobtail, its awsome!!! just watch the rear of the rocker cover fouling on the bulkhead, mines a bit tight! Used disco mounts seam welded on, very easy conversion took a whole day to do including gearbox aswell Nice one! And if you don't mind .. ........what gearbox did you use? if it was a 4 spd, what adapter did you get ..? and exhaust....? Cheers mate. Quote Link to comment Share on other sites More sharing options...
Phil.Mcavity Posted May 4, 2006 Share Posted May 4, 2006 Nice one! And if you don't mind .. ........what gearbox did you use? if it was a 4 spd, what adapter did you get ..? and exhaust....? Cheers mate. I used the disco LT77s gearbox LT230 transferbox and full disco exhaust system. It helped that the disco was parked next to the bobtail at the time!!! Disco gearbox crossmember bolts straight in to, if you dont have one the range rover one needs modifying to allow the exhaust to fit properly. Not sure if there is an adaptor plate for the 200 onto an LT95 box, Motor and Diesel would be the people to ask Quote Link to comment Share on other sites More sharing options...
2drdan Posted June 2, 2006 Author Share Posted June 2, 2006 Well parts are arriving slowly, v8 is out, conversion plate, clutch, rad are here and i've ordered crank seal, gasket etc to fit conversion plate to tdi. in my ignorance i hadn't realised it replaces the original flywheel housing!! thought the hole was a bit small for the clutch....... Just got to work out the clutch friction plate fitting, I've been told a series III centre will fit the clutch plate and the LT95 shaft...will compare v8 as well................see how we go tommorow! Quote Link to comment Share on other sites More sharing options...
