Wex Posted February 11, 2010 Share Posted February 11, 2010 90 TD19J 1990 I'm replacing both propshafts.On the vehicle I'm changing out the orientation of the old shafts was : Rear: male end ( narrow end) bolted to rear diff & wide end bolted to rear of transfer box Front:Male end bolted to front diff & wide end bolted to front of transfer box I have a C reg ('86?) which I use for parts so out of curiosity I had a look at the make up on that vehicle : Rear: male end to transfer box & wide end to rear diff Front: Male end to front diff & wide end to front of transfer box ( same as the first vehicle) Which way should they be orientated or does it matter ? The first vehicle has been mucked about with a bit , so I'm dubious about replacing like for like. Cheers. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 11, 2010 Share Posted February 11, 2010 Sliding joint end to the transfer box, both front and back. Quote Link to comment Share on other sites More sharing options...
Wex Posted February 11, 2010 Author Share Posted February 11, 2010 Sliding joint end to the transfer box, both front and back. Cheers David The reason I'm renewing is a woeful vibration in the drivetrain.Beides UJ wear , would the fact that props weren't placed correctly affect their balance and contribute to the problem ? Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted February 11, 2010 Share Posted February 11, 2010 I have always wondered this and got both orientations from proffessionals including various mechanics including Landrover ones and Devon 4X4. The most sensible was the theory that they should be put onto the vehicle so that any moisure cannot flow into the sliding joint with gravity. Still don't know the actual answer and would be interested to know including any reasonaing behind it. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted February 11, 2010 Share Posted February 11, 2010 Cheers David The reason I'm renewing is a woeful vibration in the drivetrain.Beides UJ wear , would the fact that props weren't placed correctly affect their balance and contribute to the problem ? hi, according to haynes, chapter 8.2 sliding end points to front axle on front prop and sliding end on the back prop towards tranfer box, from experience i had virbration when my rear prop was wrong way round, i have d90 1987 td, defender dinky Quote Link to comment Share on other sites More sharing options...
Wex Posted February 11, 2010 Author Share Posted February 11, 2010 Interesting DD , thanks . Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2010 Share Posted February 11, 2010 LR manual states both sliding joints at Transfer box end, Refer to paragraph 4 on this page from LR RAVE 300Tdi workshop manual Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted February 12, 2010 Share Posted February 12, 2010 Dont to forget to make sure thet the front prop is 45 degrees 'out of phase' NOT inline as almost every other vehicle! slide it off the splines and rotate it 2 splines so that the knuckles are 45 deg out, 1 spline is 22.5 deg out. Quote Link to comment Share on other sites More sharing options...
Wex Posted February 12, 2010 Author Share Posted February 12, 2010 Thanks for the help.New props fitted as per RAVE above.No more "bad-vibes " Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2010 Share Posted February 12, 2010 Thanks for the help.New props fitted as per RAVE above.No more "bad-vibes " excellent result Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 2, 2011 Share Posted August 2, 2011 Old thread resurrection time, Haynes manual says front prop sliding end to diff, Rave says sliding ends to transfer box Scanned '93 WSM from Retroanacondas site says nothing about orientation, Scanned WSM (unsure of date I think 1984) says nothing of orientation, Series 3 manual says sliding sections to the front, I know it's a different vehicle but may be where Haynes got it from..... Does it actually make any difference which way around it is fitted? and if it does why? I have read about the out of phase bit but regardless of which way around the prop is it will still be out of phase by the same amount won't it? I'm confused :s Quote Link to comment Share on other sites More sharing options...
western Posted August 4, 2011 Share Posted August 4, 2011 fit as per the info above, no chance of any unwanted vibs if the UJ's are in good order, plus it do do with the arc of movement of the suspension/transmission while in motion. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 4, 2011 Share Posted August 4, 2011 In which case I'll leave the orientation as is (which is as rave) check phasing is correct and look elsewhere for my bad vibes .... only happens about 55 mph Quote Link to comment Share on other sites More sharing options...
