oap Posted February 12, 2010 Share Posted February 12, 2010 I would like to know how much work or money it would take to fit a P.T.O to a standard td5 110 hard top, only to drive a timber spliter? It may be more than buying a small tractor any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted February 13, 2010 Share Posted February 13, 2010 the hard part is finding a good serviceable PTO unit & associated controls. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted February 13, 2010 Share Posted February 13, 2010 Agreed with Ralph - very hard and expensive to find a hydro PTO for the LT77. I gave up and bought a mechanical PTO, and made a spacer / adaptor plate so a hydraulic pump bolted on. It retained the dog clutch from the mechanical unit. Nice project to do if you've for a lathe and mill. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 13, 2010 Share Posted February 13, 2010 I bought an ex utilities H14 winch, bumper, hydraulic pto, spool valves, morse lever, tank, extra hydraulics take off etc etc for £400 ... I have seen them on ebay since too. Sometimes the Defender Centre in stourbridge have them for sale. They sell ex utilities 110's and sometimes remove the winch set ups. Only draw back with fitting the above to a td5 is you need to relocate the ECU to mount the tank there. Not a massive job but a bit fiddly. Here's a link to the defender centre: Quote Link to comment Share on other sites More sharing options...
landmannnn Posted February 13, 2010 Share Posted February 13, 2010 I would get a stand-alone pump, starting at £300ish it is probably the cheapest option. My link Quote Link to comment Share on other sites More sharing options...
oap Posted February 13, 2010 Author Share Posted February 13, 2010 Thanks for all the advice lads I've somewhere to start now. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted February 13, 2010 Share Posted February 13, 2010 Agreed with Ralph - very hard and expensive to find a hydro PTO for the LT77. Si, do you mean the LT230? the LT77 isn't fitted to a TD5 (R380), the drive comes out back of tranfer case blanking? Pete Quote Link to comment Share on other sites More sharing options...
oap Posted February 13, 2010 Author Share Posted February 13, 2010 I would get a stand-alone pump, starting at £300ish it is probably the cheapest option. My link That looks like a winner, Thanks I'll look into them. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted February 14, 2010 Share Posted February 14, 2010 Si, do you mean the LT230? the LT77 isn't fitted to a TD5 (R380), the drive comes out back of tranfer case blanking? Pete Yup, my mistake. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 15, 2010 Share Posted February 15, 2010 Usually one or two PTO's on eBay, just make sure you get a Defender one not a Series one. Depending on the flow required, bolting an extra pump to the engine could be another way. We've done it plenty with hydraulic winches. Quote Link to comment Share on other sites More sharing options...
