all_black Posted February 19, 2010 Share Posted February 19, 2010 Newbie question coming up... I am planning on putting a set of BFG ATs on my recently purchased Defender Td4. What is the biggest size I can go for without modifying the car? (suspension, wheel spacers etc.) Is it 265 or can I go for 285 without causing problems for myself? And does anyone have a link to a picture of a Defender Td4 with either of the ATs mentioned... Just to check out the appearance... Thanks a lot! Best Regards SHA Quote Link to comment Share on other sites More sharing options...
petethepilot Posted February 19, 2010 Share Posted February 19, 2010 I have 305/70/16. No suspension mods, no lifting. Only 8X16 Compomotive wheels. Maybe possible to fit even 315/70/16 but then needing to adjust the steering limiter bolts/reducing turning circle a bit. Sorry, no place to host the pictures... but can send PM if you need. There it is in Avatar, but small. Quote Link to comment Share on other sites More sharing options...
western Posted February 19, 2010 Share Posted February 19, 2010 Sorry, no place to host the pictures.. you can upload a photo direct to your reply. Quote Link to comment Share on other sites More sharing options...
all_black Posted February 20, 2010 Author Share Posted February 20, 2010 Thanks PeteThePilot But it looks like your tires are sticking out from the car. That is not allowed where I live :-) So that would require a modification... So I doubt that 305 is actually possible on a Defender Td4 without modes. Anyone else? Quote Link to comment Share on other sites More sharing options...
BigSi110 Posted February 20, 2010 Share Posted February 20, 2010 Sorry about the poor picture, but the red 110 is an '09 model with 285/75/16 BFG AT's on 8" Compomotive rims. No mods, no changes. Works fine. The blue Tdi behind is also on 285's, but Cooper STT's. My point is that the tyre make may actually make a difference. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 20, 2010 Share Posted February 20, 2010 265/75/R16 is a factory-fitted size, so that shouldn't be a problem. With regard to larger sizes, different wheels with different off-set values will affect whether the tyres stick out or not. And steering lock on the front Quote Link to comment Share on other sites More sharing options...
petethepilot Posted February 21, 2010 Share Posted February 21, 2010 Thanks PeteThePilot But it looks like your tires are sticking out from the car. That is not allowed where I live :-) So that would require a modification... So I doubt that 305 is actually possible on a Defender Td4 without modes. Anyone else? Actually it´s the same law in here. The side of the tire can stick out, but not the tread itself. And these are just legal. Got MOT 2 weeks ago. Not sure about 315´s though... Quote Link to comment Share on other sites More sharing options...
q-rover Posted February 21, 2010 Share Posted February 21, 2010 255.85x16 will fit no problem on standard 7x16 rims. About 33.3" tall tyre. Quote Link to comment Share on other sites More sharing options...
all_black Posted February 21, 2010 Author Share Posted February 21, 2010 OK. Thanks... 255.85x16 could be a possible solution. Good height - sensible width. Can anyone post a picture of this combination? SHA Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2010 Share Posted February 21, 2010 OK. Thanks... 255.85x16 could be a possible solution. Good height - sensible width. Can anyone post a picture of this combination? SHA My 110 on 255/85 BFG MT's with XD/Wolf steel wheels. Quote Link to comment Share on other sites More sharing options...
petethepilot Posted February 21, 2010 Share Posted February 21, 2010 Finally I managed to upload the image, had to adjust the settings and resize it. I have a better one also somewhere, but couldn´t find it right now. But as you can see, the answer to your question what is the biggest possible, we are getting near here... but still legal. 8x16 Compomotives, 305/70/16. I like them... Actually there doesn´t seem to be very big difference between these and those 285´s in previous picture. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 21, 2010 Share Posted February 21, 2010 Here's my 90 with 255/85/16's on silver modular wheels, standard suspension etc. Pete Quote Link to comment Share on other sites More sharing options...
JST Posted February 22, 2010 Share Posted February 22, 2010 255.85x16 will fit no problem on standard 7x16 rims. About 33.3" tall tyre. 255.85s will go does anyone do these as an AT pattern? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 23, 2010 Share Posted February 23, 2010 255.85s will go does anyone do these as an AT pattern? James, The closest to an AT I could find in 255.85X16 is the Cooper Discoverer ST :- Click Me I have had this set on both the Discovery and now the 90 and they seem to handle reasonably well in all conditions and are wearing well. Pete Quote Link to comment Share on other sites More sharing options...
JST Posted February 23, 2010 Share Posted February 23, 2010 Cheers Pete Quote Link to comment Share on other sites More sharing options...
manfred Posted July 27, 2011 Share Posted July 27, 2011 I've got 33mm wheelspacers 285 75 r16 on dotz Dakar 7 16 rim's The dotz got 25 mm extra so i've got a wheelarch extension And now i 've got it after 6 attamps( sorry spelling) Through german mot The Cars Dimension had to be changed The Width of the car got 4% over max what landrover Germany permits But it that is permitted Your mot is a laugh Please let me have an english mot But what if i tried bigger Size wheels Would that improve drivability in mud? Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 27, 2011 Share Posted July 27, 2011 Why do you want such oversized tyres? They're bad for performance, economy, handling, off road ability and steering/wheel bearing wear. Their only benefit is for sand or deep snow driving. I would keep to 235/85 or 7.50 - that what LR found most effective for the Camel Trophy and the British Army and Royal Marines found most effective for almost every combat environment. Quote Link to comment Share on other sites More sharing options...
GL88 Posted July 27, 2011 Share Posted July 27, 2011 A few points: - Depending on how concerned you are with tyre life I'd stick with the BFG ATs. They perform well on road and aren't bad on non-extreme offroad conditions. And they have a very good reputation for longevity. I only replaced the fronts on mine last year after 67K miles and they were still perfectly legal. The original rears are still on at 72K with about 7mm of tread but will need to go because the side walls are crazing badly from the sun now. - Mine is on the original factory fitted 265/75 size which is obviously fine. - There are two reasons to look for a taller tyre (three if you include cosmetic appearance). Firstly it increases the axle clearance and the lowest point on the diffs is the limiting factor for offroad clearance in a lot of situations and no amount of suspension lifting changes this. Secondly a larger diameter tyre sinks less on soft terrain. Quote Link to comment Share on other sites More sharing options...
manfred Posted July 27, 2011 Share Posted July 27, 2011 Thank you for answering I 've got the wheelspacers for my snowchains as i do go to norway or sweden at times but i did readjust the steering thingimigic cause i got some noise from those chains in the Forest in tight tree conditions Well i'll be round soon to visit my kids in bournemouth and brighton But Not a Lot of Snow Just a Lot of old people As Jack Dee Said Anyway in germany every offroad place will tell you 255 85 r16 from Cooper the st's Are the best I found the 285 75 r16 stt from cooper very good even in winter Just louder and louder Well makes the engine quiet I was just wondering about bigger tyres in mud and snow Manfred Quote Link to comment Share on other sites More sharing options...
