Dan88 Posted April 22, 2010 Share Posted April 22, 2010 I'm looking to change the 3.5 v8 in my '86 90 to a 3.9efi. I have a serpentine engine, ecu, etc. an also a standard 3.9efi. What is best an why? Thanks Quote Link to comment Share on other sites More sharing options...
zardos Posted April 22, 2010 Share Posted April 22, 2010 I'm looking to change the 3.5 v8 in my '86 90 to a 3.9efi. I have a serpentine engine, ecu, etc. an also a standard 3.9efi. What is best an why? Thanks my thoughts of 3.5 v8 vs 3.9 efi serpentine. 3.9 has more power and should be better fuel economy. 33% more efficient oil pump runs a better alternator runs at more extreme angles than some carbs. Enough said. Quote Link to comment Share on other sites More sharing options...
zim Posted April 23, 2010 Share Posted April 23, 2010 The serp oil pump is better than the dizzy driven oil pump Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted April 23, 2010 Share Posted April 23, 2010 Serpentine gets my vote Advantages as stated above plus the following: The improved oil pump drive which (since I am a Megajolt fan) means the ability to run it without a distributor. Ten bolt heads The ability to change the auxiliary drive belt with one 15mm spanner in about 10 seconds... As a comparison: On my old 3.9 there were three belts, the adjustment of which involved undoing the tensioner, the steering pump and the alternator mountings and a LOT of grunting and levering to get them all back tensioned again. The job was made easier if I removed the distributor first for access to the steering pump. Also, although apparently not necessary, if replacing one of the belts I also found I had to to remove the fan cowl - which meant removing the viscous fan... So when away from home I would need to carry 3 spare belts (they are all different), six spanners, a Phillips screwdriver, a big tyre-lever for use in tensioning, and a fan-spanner just to cover the possibility of a broken belt. Now I will carry one serpentine belt and one spanner. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 23, 2010 Share Posted April 23, 2010 Totally agree with Three Sheds and Zim ^^^^^ Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 23, 2010 Share Posted April 23, 2010 Serp every time for me, oil pump and ancillary belt being the main reasons I went one stage further and got a P38 4.0l engine, no dizzy at all then Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted April 23, 2010 Share Posted April 23, 2010 Sorry - just thought of some small down-sides: The serpentine engine has it fan in a different position so your fan-cowl wont fit properly. It also rotates the other way so make sure you get one with the engine. The power-steering, water and oil cooler pipes are all different - you may need to get some made up from your old ones. HTH Roeer Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 23, 2010 Share Posted April 23, 2010 ^^^ As above for Serp V8s, plus the Serps tend to be cross bolted blocks makes stonger unit IMHO Nige Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 23, 2010 Share Posted April 23, 2010 Sorry - just thought of some small down-sides: The serpentine engine has it fan in a different position so your fan-cowl wont fit properly. It also rotates the other way so make sure you get one with the engine. The power-steering, water and oil cooler pipes are all different - you may need to get some made up from your old ones. HTH Roeer On the fan cowl issue, the one from a 50th V8 fits perfectly My serp engine came from a Disco, the oil cooler pipes line up perfectly with the Turbo D rad I am using. Hoses - use bottom hose from donor vehicle, and header tank. Mods will be minor and pretty easy. Top hose can be cobbled from the serp top hose and your original with a joiner/piece of pipe and a couple of hose clips. PAS hoses are indeed different, but again, if you have the pipes from the donor car you should have enough bits to cobble together what you need. Quote Link to comment Share on other sites More sharing options...
