simonr Posted October 21, 2010 Share Posted October 21, 2010 I washed all the grease out of the gearbox and gave it a spray of PTFE Lube (intended for Photocopiers) which has made it much more free - but not free like a Delta-Tek! I'll get on it over the weekend! I think I still have some lumps of EN24 from the Delta-Tek prototypes under my bench. The dual motor conversion I made makes the winch 5" narrower - so I guess a wide (and / or bigger diameter) drum version is also viable. Si Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 21, 2010 Share Posted October 21, 2010 Dual Motor TDS? Nice! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 21, 2010 Share Posted October 21, 2010 Ross, I take it you missed this: http://forums.lr4x4.com/index.php?showtopic=61570 Quote Link to comment Share on other sites More sharing options...
general-confusion Posted October 21, 2010 Share Posted October 21, 2010 I would just like Delta Tek to make MORE freespooling drums its a great idea but pointless if you cant get hold of one , been waiting since Billing and have orders in with Challenger 4x4 but I believe no one has stock of the +3 inch Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 21, 2010 Share Posted October 21, 2010 Ross, I take it you missed this: http://forums.lr4x4.com/index.php?showtopic=61570 Thank you, I'd missed that... Not been on the forum much in the last couple of days. That looks great Si Quote Link to comment Share on other sites More sharing options...
simonr Posted October 21, 2010 Share Posted October 21, 2010 I would just like Delta Tek to make MORE It's no consolation - but even I'm still waiting for one! They are being produced as fast as possible - it's just demand is totally outstripping supply at the moment! Have you tried PMing Nick directly? Si Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted October 22, 2010 Share Posted October 22, 2010 I washed all the grease out of the gearbox and gave it a spray of PTFE Lube (intended for Photocopiers) which has made it much more free - but not free like a Delta-Tek! I'll get on it over the weekend! I think I still have some lumps of EN24 from the Delta-Tek prototypes under my bench. The dual motor conversion I made makes the winch 5" narrower - so I guess a wide (and / or bigger diameter) drum version is also viable. Si hmmmm could you build a TDS twinmotor big drum hybrid turbo nutter winch to fit the gigglepin bolt pattern? Quote Link to comment Share on other sites More sharing options...
JST Posted October 23, 2010 Share Posted October 23, 2010 we won the HW series last year with a TDS on the rear of RV4, freespool, B2 and large drum, 12000lb version. if your just getting into it a TDS will work well and can then move to the back. Orange - your losing confidence in it as the rope slips off the grub screw! - Splice the rope on then. Quote Link to comment Share on other sites More sharing options...
