freeagent Posted June 12, 2006 Share Posted June 12, 2006 this is a bit odd (needs sound) spooked me a bit.. http://www.milaadesign.com/wizardy.html m@tt. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 12, 2006 Share Posted June 12, 2006 Now that is wierd. I tried it 5-times and it was right every time. I even did daft things like not looking at it for more than just a brief glance. Can't figure-out how it works either. Les. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted June 12, 2006 Share Posted June 12, 2006 Now that is wierd. I tried it 5-times and it was right every time.I even did daft things like not looking at it for more than just a brief glance. Can't figure-out how it works either. Les. school boy magic. think of the number as being made up of tweo digits a and b written as ab and its value is: 10 x a + b. now add up the two digits: a + b. subtract the two from the original number: 10a + b - (a+B) = 10a + b - a - b = 9 a. Look at the table, all the multiples of 9, which is what your result has to be, have the same symbol. SPOOKY!!!! Quote Link to comment Share on other sites More sharing options...
jules Posted June 12, 2006 Share Posted June 12, 2006 Very old my dad told me this one when I was about 13... get them every time Quote Link to comment Share on other sites More sharing options...
02GF74 Posted June 12, 2006 Share Posted June 12, 2006 Very old my dad told me this one when I was about 13...get them every time Awright then mr smarty pants jules: 1. think of a number 2. double it 3. add twelve to it 4. halve it 5. subtract the number you first thought from it 6. the number you have now is ........ 6. Quote Link to comment Share on other sites More sharing options...
jules Posted June 12, 2006 Share Posted June 12, 2006 Exactly Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 12, 2006 Share Posted June 12, 2006 Here's another one that will keep the idiots thinking for ages..... "think of a number..." then walk away! Quote Link to comment Share on other sites More sharing options...
pugwash Posted June 12, 2006 Share Posted June 12, 2006 didn't work for me i always think of th square root of -2 Quote Link to comment Share on other sites More sharing options...
snailracer Posted June 12, 2006 Share Posted June 12, 2006 didn't work for me i always think of th square root of -2 1.414213562i Snailracer Quote Link to comment Share on other sites More sharing options...
pugwash Posted June 12, 2006 Share Posted June 12, 2006 yeah- can give me a value for i please? the value of Pi's another good one seeing as it seems to bea never repeating number (can't remember there proper mathematical names!) Quote Link to comment Share on other sites More sharing options...
marsie Posted June 12, 2006 Share Posted June 12, 2006 OW my brain is hurting must be something to do wth being fik at skool? Paul Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted June 12, 2006 Share Posted June 12, 2006 yeah- can give me a value for i please? Yes... sqrt(-1) Quote Link to comment Share on other sites More sharing options...
minivin Posted June 12, 2006 Share Posted June 12, 2006 well, I can't figure out the mental side as I beat it the first time, and then chosing numbers off bottles and bits of paper it worked six times so far perfect, not even following a sensible thought pattern as it was the first two digit number that I would find on a sheet of paper et cetera Quote Link to comment Share on other sites More sharing options...
02GF74 Posted June 13, 2006 Share Posted June 13, 2006 yeah- can give me a value for i please?the value of Pi's another good one seeing as it seems to bea never repeating number (can't remember there proper mathematical names!) ^^^^ irrational number. didn't work for me i always think of th square root of -2 Wrong; that is a formula not an number. Unfortunately neither you nor anyone else can think of the actual value (square root of 2) as it has no end nor any repeating sequence; another example of irrational number. Quote Link to comment Share on other sites More sharing options...
simonr Posted June 13, 2006 Share Posted June 13, 2006 school boy magic.think of the number as being made up of tweo digits a and b written as ab and its value is: 10 x a + b. now add up the two digits: a + b. subtract the two from the original number: 10a + b - (a+B) = 10a + b - a - b = 9 a. Look at the table, all the multiples of 9, which is what your result has to be, have the same symbol. SPOOKY!!!! This is quite clever, by changing the symbol in the table which coresponds to the multiples of 9, you tend not to notice that all the multiples have the same symbol. About the best implementation I've seen! (even had me going for a bit!) Si Quote Link to comment Share on other sites More sharing options...
pugwash Posted June 13, 2006 Share Posted June 13, 2006 ^^^^ irrational number.Wrong; that is a formula not an number. Unfortunately neither you nor anyone else can think of the actual value (square root of 2) as it has no end nor any repeating sequence; another example of irrational number. welkl tecnhically the square root of -2 is a description of a number- and no one said in the first example that you had to think of an integer did they? technically the root of a negative cannot be an irrational number, it has to be an imaginery numbe, as the answer cannot be conceptualised. Quote Link to comment Share on other sites More sharing options...
