Mark Posted April 12, 2011 Share Posted April 12, 2011 Does anyone have a source of the square nuts that fit into the castings on an 8274 to hold it onto its mounts (eg bumper, etc)? The ones I have are threaded 7/16" UNC - and I have got some bolts, but cannot seem to find any square nuts in this threadform.... I have visited my usual suppliers of strange fastenings, and they all look at me blankly when I ask, so any help finding some would be very much appreciated. Cheers Mark Quote Link to comment Share on other sites More sharing options...
zardos Posted April 12, 2011 Share Posted April 12, 2011 These people (http://www.nufast.co.uk/ourproducts_view.asp?ID=1) might do some square weld nuts in the right size. Or cage nuts are square (just remove the cage) Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 12, 2011 Share Posted April 12, 2011 I binned mine and used M10 8.8 bolts with Uni strut M10 Zebs with one end cut back and the spring pulled off or it might have been M12 Quote Link to comment Share on other sites More sharing options...
simonr Posted April 12, 2011 Share Posted April 12, 2011 I'm sure you have some bar and an M10 tap? Si Quote Link to comment Share on other sites More sharing options...
MrKev Posted April 12, 2011 Share Posted April 12, 2011 I have some 17mm square nuts, but I just checked and they're threaded 3/8UNC. Sorry! Quote Link to comment Share on other sites More sharing options...
Superpants Posted April 12, 2011 Share Posted April 12, 2011 The main fastener distributors in UK that I have check (Fabory, bossard) don't stock them- Your favourite fastener distributor generally uses Fabory... Quote Link to comment Share on other sites More sharing options...
Tractorboy16 Posted April 12, 2011 Share Posted April 12, 2011 i use a normal M10 8.8 with a nylock on the end. If you get a flat screwdriver it fits in a treat and you shall be able to do up as tight as you can and then simply remove the screw driver. Easy as and far cheaper than the ali square nuts i seemed to round off every time i used them. James Quote Link to comment Share on other sites More sharing options...
simonr Posted April 12, 2011 Share Posted April 12, 2011 Using a regular nyloc nut does have the advantage that it's harder for our mobile brethren to undo! Si Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted April 12, 2011 Share Posted April 12, 2011 I have done the same, M10 12.9 cap head bolts with nylocks, works a treat! just use a flat screwdriver as suggested. Steve Quote Link to comment Share on other sites More sharing options...
landy andy. Posted April 12, 2011 Share Posted April 12, 2011 Could try http://www.arbil4x4.co.uk/index.php Andy Quote Link to comment Share on other sites More sharing options...
Brookers Posted April 12, 2011 Share Posted April 12, 2011 They are listed on the Devon 4x4 site Quote Link to comment Share on other sites More sharing options...
zardos Posted April 12, 2011 Share Posted April 12, 2011 They are listed on the Devon 4x4 site You mean http://www.devon4x4.com/index.php?page=shop.product_details&product_id=215&option=com_virtuemart&Itemid=14 Quote Link to comment Share on other sites More sharing options...
D3DPE Posted April 13, 2011 Share Posted April 13, 2011 HI, The nuts are available from any Uk Warn distributor part number - 7616 they are £1 each +vat using the forum discounts. (see signature for discount) You can also drill the casing and winch mount out to a 12mm hole and use a m12 nut and bolt, this is how I have always fitted the winch. Hope it helps. Dan Quote Link to comment Share on other sites More sharing options...
gazelle Posted April 13, 2011 Share Posted April 13, 2011 Simon, What happened to these you were developing? Martin Quote Link to comment Share on other sites More sharing options...
MrKev Posted April 13, 2011 Share Posted April 13, 2011 I was just wandering that too. Could do with a couple in M10 and a couple in M12.... Quote Link to comment Share on other sites More sharing options...
