davidlandy Posted April 19, 2011 Share Posted April 19, 2011 the other week my transmission started whine and its getting progressively worse I noticed the rear diff pinion had masses of play in it so sorted that, new ujs on the rear prop. the noise happens around 30mph and gets louder the more throttle is applied, it sounds like its coming from the tunnel area. is it more likley to be the gearbox than the transfer box? or how can i tell which it is thats the offending bit ? many thanks for your help guys Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted April 19, 2011 Share Posted April 19, 2011 Is the noise still there in low range in the same gear/throttle as you be at 30 in high range? if the noise isn't there then its not gearbox, but if it still is there it is most likley, but I suppose it could also be transfer box input. If your rear diff pinion had lots of play in the crownwheel and pinion gear may be worn, causing the noise. Try removing the rear prop and going for a drive, then you should find if its that. HTH Quote Link to comment Share on other sites More sharing options...
Gromit Posted April 20, 2011 Share Posted April 20, 2011 Tunnel area is probably gearbox. Does the noise occur in all gears, all gears but 4th or just one gear? You can try changing the oil and see what comes out / see if the noise changes or stops. Quote Link to comment Share on other sites More sharing options...
davidlandy Posted April 20, 2011 Author Share Posted April 20, 2011 hi guys the transfer box oil was like choclate so changed it and noise is still evident. it happens around 35mph, in certainley 3,4,5th gears. the noise varies on throttle application so gets noiser for example if accelerating in 4th at 40mph rather than 3rd if that makes sense. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted April 24, 2011 Share Posted April 24, 2011 Change all the oils and check what they look like and check for metal particals. Try driving with one, then the other prop shaft removed. Andy Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 24, 2011 Share Posted April 24, 2011 Does it only make the noise when accelerating? or does it also do it when on overrun? Quote Link to comment Share on other sites More sharing options...
davidlandy Posted April 24, 2011 Author Share Posted April 24, 2011 drove it without the front prop on and it still made the same noises so took a chance and slung in another transfer box , and guess what still the same which only leaves the gearbox i guess. losing the will to live with it now! is a disco and defender r380 gearbox the same or interchangeable? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 24, 2011 Share Posted April 24, 2011 No, disco and defender R300s are different. the disco gearbox levers come out much further back. On a defender the disco sticks would come out of the seatbox! Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted April 24, 2011 Share Posted April 24, 2011 I,m sure the gearboxes are the same, just need to change over the gear selectors and gear sticks etc or whatever they are called at the top of the gearbox . correct me if I'm wrong, wouldn't be the first time Brian Quote Link to comment Share on other sites More sharing options...
Mr Ian Posted April 24, 2011 Share Posted April 24, 2011 Hi sorry you are wrong, needs a new selector rail as well as the shifter housing, this means a total strip down. Regards Ian Ashcroft Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2011 Share Posted April 24, 2011 drove it without the front prop on and it still made the same noises so took a chance and slung in another transfer box , and guess what still the same which only leaves the gearbox i guess. losing the will to live with it now! is a disco and defender r380 gearbox the same or interchangeable? have checked &/or replaced the diff & main gearbox oil to eliminate them for the possible noise making ? Quote Link to comment Share on other sites More sharing options...
sharpy Posted May 1, 2011 Share Posted May 1, 2011 Hiya, I have just cured the same problem on my 1987 90, in my case if was the diffs, there was a little play in them, but I put up with the noise thinking it was from the 33x12.5 tyres. Finally I gave in and bought 2 new diffs as the front was leaking now quite badly and taking the wheels, halfshafts etc. out whilst on axle stands on my sloped drive wasn't my happiest of choices. But it did the trick and has made the drive superb, feels like a new truck. Paul Quote Link to comment Share on other sites More sharing options...
