Mark90 Posted July 13, 2006 Share Posted July 13, 2006 I'm trying to build and fit my winch ready for Tony's bash and I need a new oil seal for the brake shaft, part number 7612. At the moment this is only available as part of the extortionately priced brake service kit at £80-90 However in a few(?) weeks time these will be avilable to buy individually, but unfortunately this is likely to be a bit late for me to have the winch ready for Tony's bash. As I don't need the full brake kit I'm rather reluctant to spend £90 just to get a seal, so does anyone have a seal laying around, maybe from a brake kit that you haven't used, that I could 'borrow' for the time being? It'll be replaced as soon as the seals become available. Bish will be most grateful that I have a winch to drag him out if when he gets stuck TIA Quote Link to comment Share on other sites More sharing options...
Tonk Posted July 13, 2006 Share Posted July 13, 2006 got a piccy of wot u need? i cant quite picture it at mo, have got some spares at home Quote Link to comment Share on other sites More sharing options...
white90 Posted July 13, 2006 Share Posted July 13, 2006 can't you re use the seal you had? or is it bugg***d if it is D44/First Fouroffroad/David bowyer/phil at PG or ARBIL direct they sold me spares directly before now. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted July 13, 2006 Author Share Posted July 13, 2006 It is bugg***d, didn't want to come out easily. I could try taking one out of the other winch, but don't know if it'll come out intact either, and would rather fit a new seal anyway. Have tried Phil at PG and he hasn't got any for a couple of weeks, in fact it sounded liek he didn't have much of anything in for a couple of weeks. It seems most places only sell the seal as part of the brake service kit. Will take a photo when I get home, but it is the rubber lipped seal that goes on the brake shaft next to the bronze bush. Quote Link to comment Share on other sites More sharing options...
white90 Posted July 13, 2006 Share Posted July 13, 2006 gwyn lewis? ARBIL have them on back order for 2 weeks D44 have them on back order with ARBIL so does Phil Quote Link to comment Share on other sites More sharing options...
RocKeR Posted July 13, 2006 Share Posted July 13, 2006 Any help from this lot, as posted by SteveG as while back? Quote Link to comment Share on other sites More sharing options...
Diff Posted July 13, 2006 Share Posted July 13, 2006 I don't know what they look like, but if it is a conventional seal, you should be able to get one at a bearing/seal supplier (have a look in the yellow pages for your nearest one). If you take it in, they will usually match it for you. If there are no numbers on it and it is mashed beyond recognition, measure the shaft diameter, the oil seal location diameter and the thickness of the seal, and that should be enough to get you a replacement. Regards, Diff Quote Link to comment Share on other sites More sharing options...
white90 Posted July 13, 2006 Share Posted July 13, 2006 I've left a msg with Warn USA to see if they'll ship internationally they have the part in stock for $4.95 plus shipping I guess Quote Link to comment Share on other sites More sharing options...
GBMUD Posted July 13, 2006 Share Posted July 13, 2006 I've left a msg with Warn USA to see if they'll ship internationallythey have the part in stock for $4.95 plus shipping I guess Worst case, I have a friend who will be travelling to the States between now and then and will be back before Tony's. I can ask him to bring one if needed. Bearing and seal supplier is probably best though, they should be able to sort you out. Chris Quote Link to comment Share on other sites More sharing options...
Mark90 Posted July 13, 2006 Author Share Posted July 13, 2006 Rocker, I have e-mailed them to ask about shipping to the UK, ie if they do it, how much, how long, etc. Diff, that was my thought (the numbers are still readable) but apparently it's not a standard seal, people have tried and failed. Tony, thanks. Quote Link to comment Share on other sites More sharing options...
PeterW Posted July 13, 2006 Share Posted July 13, 2006 Rocker, I have e-mailed them to ask about shipping to the UK, ie if they do it, how much, how long, etc.Diff, that was my thought (the numbers are still readable) but apparently it's not a standard seal, people have tried and failed. Tony, thanks. Windrock have them as a stock item and ship to the UK from the US Cheers Pete Quote Link to comment Share on other sites More sharing options...
Mark90 Posted July 13, 2006 Author Share Posted July 13, 2006 Thanks will give them a try. Gwyn has had a rumage through his spares for me and doesn't have any in stock. No answer at Ryders. Quote Link to comment Share on other sites More sharing options...
SteveG Posted July 13, 2006 Share Posted July 13, 2006 Thanks will give them a try.Gwyn has had a rumage through his spares for me and doesn't have any in stock. No answer at Ryders. Hi Mark I'm pretty sure I have one, I'll go and have a look Steve Quote Link to comment Share on other sites More sharing options...
SteveG Posted July 13, 2006 Share Posted July 13, 2006 Hi MarkI'm pretty sure I have one, I'll go and have a look Steve Yes I do, the metal has got some surface rust , but the rubber skirt and spring are tip top PM me your address and I'll post it to you. Les B - if you are reading this post I also found a new bearing for the motor so you won't need one of these Steve Quote Link to comment Share on other sites More sharing options...
Mark90 Posted July 13, 2006 Author Share Posted July 13, 2006 Thanks Steve, you are a star. PM on it's way. Quote Link to comment Share on other sites More sharing options...
