how much longer?
Didnt help at all, and once again you have proven absolutely useless - please refrain from answering my thread, you clutter up threads with useless replys as is, please don't do it to mine.
I was asking for actual accurate measurements.
Also wouldn't these factors also affect how much further forward any change would put your gearstick.
1 - The bellhousing you planning to use as shown here http://forums.lr4x4.com/index.php?showtopic=7397 there are multiple options.
2 - If I remember correctly the tdi and v8 main shafts in the LT77 are different lengths (Hence different Bell Housings) on a Discovery's.
As thus without clarrifying the above terms no measurement could be accurate as truth is not known.
This is an LT77 from a discovery / RR v8 compared to an LT77 from a 200tdi defender.
Hope that helps. I'm away from home so can't take any other measurements.
G
