Sammy_D Posted June 7, 2011 Share Posted June 7, 2011 Hey guys. Going to give my 90 a good clean underneath. Take the diff protectors off and scrape out all mud. I heard of a thing called wax oil?? Can you make this? Also what else can I do to the under side? Ta Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted June 7, 2011 Share Posted June 7, 2011 This is what you are after (although Halfords ain't necessarily the best place to buy it - any motor factor is likely to keep it in stock. When I re-built mine, I gave the underside of the tub a liberal coat of 3M Shutz before I re-assembled it. There's no point in putting the stuff on anything other than a clean, dry surface but if you can clean it up enough to paint then this will help ward of the metal moth for a while longer. NIck. Quote Link to comment Share on other sites More sharing options...
Sammy_D Posted June 7, 2011 Author Share Posted June 7, 2011 Thanks nick. Where are the main parts to protect? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted June 8, 2011 Share Posted June 8, 2011 This subject has been covered on numerous occasions, do a forum search for 'Waxoyl' or Waxoil' (or variations along those lines), 'Dinitrol' 'Rustproofing' etc etc. You might like to checkout the technical forum also. Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted June 8, 2011 Share Posted June 8, 2011 Places where corrosion is the biggest problem in my experience: - Inside and outside the chassis outriggers - Anywhere on the rear cross member - The fuel filler pipe - Where the joint between the rear tub and the seat box is supported by the vertical outriggers from the chassis - The lower part of the front inner wings, where stone picked up by the wheels tend to hit them - Inside the vertical pillars at the sides of the front bulkhead, where the door hinges are fixed - The front sill support channels - Along the bottom of the doors Anyone else got any offers? Nick. Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 8, 2011 Share Posted June 8, 2011 All of the bulkhead Behind the 2nd row doors on a 110 CSW Rear A-frame mounts. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 8, 2011 Share Posted June 8, 2011 Anything steel Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted June 8, 2011 Share Posted June 8, 2011 Anything British Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 8, 2011 Share Posted June 8, 2011 Best thing you can do is CLEAN IT, mud traps water & lets it all rot while it stands. Quote Link to comment Share on other sites More sharing options...
