gazelle Posted July 23, 2011 Share Posted July 23, 2011 Bit of a basic question, but what is meant by the term "backlash"? It has been used in a number of threads recently, but I am not fully clear what it is. Can somebody please explain to me what it is, and what the symptoms are please. Cheers Quote Link to comment Share on other sites More sharing options...
rtbarton Posted July 23, 2011 Share Posted July 23, 2011 Basically it's play or lost movement between two connected items, such as splines in a differential or slackness between two gears. It can be caused by wear, in which case it is "excessive backlash" or designed in, for example to allow oil to get between the teeth of gears. Quote Link to comment Share on other sites More sharing options...
Mike Brownlie Posted July 23, 2011 Share Posted July 23, 2011 this is too much... http://www.facebook.com/video/video.php?v=10150326411026420 Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted July 23, 2011 Share Posted July 23, 2011 this is too much... http://www.facebook....150326411026420 link doesnt work my friend anyway can you get back lash in the rear prop? Quote Link to comment Share on other sites More sharing options...
western Posted July 23, 2011 Share Posted July 23, 2011 Bit of a basic question, but what is meant by the term "backlash"? It has been used in a number of threads recently, but I am not fully clear what it is. Can somebody please explain to me what it is, and what the symptoms are please. Cheers Wikipedia will explain http://en.wikipedia.org/wiki/Backlash_(engineering) don't know what was on the facebook link, but it's been removed. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 24, 2011 Share Posted July 24, 2011 Front diff backlash in all it's glory: http://www.youtube.com/watch?v=bR5FmjXXKJ0 FYI: Front axle will generally have more backlash than the rear as there are more splined joints which accumulate to more play overall. Quote Link to comment Share on other sites More sharing options...
gazelle Posted July 24, 2011 Author Share Posted July 24, 2011 Front diff backlash in all it's glory: http://www.youtube.c...h?v=bR5FmjXXKJ0 FYI: Front axle will generally have more backlash than the rear as there are more splined joints which accumulate to more play overall. Thanks, that explains it clearly! Cheers Martin Quote Link to comment Share on other sites More sharing options...
