il-bob Posted August 11, 2011 Share Posted August 11, 2011 As title, has anyone modified his fornt radius arms or are there any available on the market? Reason for this is that I want to improve front articulation but not too fond on 1, 3 or 4 link setups. Extended radius arms might improve front articulatiopn without major risks on road. bob Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted August 11, 2011 Share Posted August 11, 2011 The biggest problem I think with this, is that you would have to move all steering and the panhard forward as well.. So it would probably be just as "easy" to three or four link it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 11, 2011 Share Posted August 11, 2011 Or just move the chassis mounts back.... The restriction is more in the axles radius arm bushes, I doubt extending the arms will make a lot of difference Quote Link to comment Share on other sites More sharing options...
oddballrovers Posted August 11, 2011 Share Posted August 11, 2011 Jim Marsden off Gigglepin fame runs something modified, here captured in the bivi at this years Breslau Quote Link to comment Share on other sites More sharing options...
Ruuman Posted August 11, 2011 Share Posted August 11, 2011 north offroad do longer arms and custom mounts, but disco 2 arms could be a good option Quote Link to comment Share on other sites More sharing options...
longlandy Posted August 12, 2011 Share Posted August 12, 2011 I make the adapters and chassis mounts to fit rose or johnny joints on the end of standard factory( stronger than aftermarket junk) radius arms. Nothing new, yanks have been doing it for years, go on pirate and have a look. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2011 Share Posted August 12, 2011 I really don't think adding length to the radius arms is going to gain you anything significant and it's going to lose you a sh*tload of strength. I don't like the look of that picture you posted, there's a lot of good reasons Rover went to the trouble of casting them out of a big lump of steel. Quote Link to comment Share on other sites More sharing options...
longlandy Posted August 12, 2011 Share Posted August 12, 2011 I really don't think adding length to the radius arms is going to gain you anything significant and it's going to lose you a sh*tload of strength. I don't like the look of that picture you posted, there's a lot of good reasons Rover went to the trouble of casting them out of a big lump of steel. Thats why I keep the standard arms and just joint the ends to get rid of the restrictive bush, I find those qt things worrying bits of junk Quote Link to comment Share on other sites More sharing options...
il-bob Posted August 12, 2011 Author Share Posted August 12, 2011 I read on another forum that with the extended radius arms, the guy who has them got better steering lock. Could that be true? I imagine u get better articulation because with the same angle before the bush binds, vertical movement of axle is increased because it is fuerther away then before. And might also get the most out of slotted bushes Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted August 12, 2011 Share Posted August 12, 2011 There are indeed many downsides to the link system on the front of a coiler, the only way to really get around it is to make something completely new I'm afraid. And lets face it, lengthening the arms and moving mounts is just as bad as making a completely new system, MOT wise. So what about a single link, utilizing the existing panhard for control? The Norwegians has done it for years with no mention able problems. It leaves more room than 3-4 link setups. Or just fit leafs, lighter and with loads more travel potential Quote Link to comment Share on other sites More sharing options...
