Baz2236 Posted September 21, 2011 Share Posted September 21, 2011 Hi I have just fitted some +5 shocks to the back of my 90 I also fitted the pointey dislocation cones to get the spring back in the right place. Whilst out trying them out today I noticed that the Spring drops further then the cone but then falls the other side of the cone so when it compress the spring is completely the wrong place. Any ideas how I can sort these out do the other cones which are shaped like a tube work better then these spike ones. what do others use or I suppose I could space the cone down further ideas please. Thanks in advance. Baz Quote Link to comment Share on other sites More sharing options...
Sirocco Posted September 21, 2011 Share Posted September 21, 2011 Gwyn Lewis does them with a little hook/catcher which grabs the spring as it passes (I presume). Most people dont dislocate below the normal style cones so they suit most applications. I think you need to be looking at other types of cone. G Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted September 21, 2011 Share Posted September 21, 2011 Gwyn Lewis everytime as an off the shelf option. Otherwise you can make some bottom mounted ones simple enough and retain the spring at the top Quote Link to comment Share on other sites More sharing options...
landy andy. Posted September 21, 2011 Share Posted September 21, 2011 As above. Gwyn Lewis with the hook to catch the last coil. Works well Andy Quote Link to comment Share on other sites More sharing options...
Boris113 Posted September 22, 2011 Share Posted September 22, 2011 My friend had this problem his +5s and cones, he got some angled ones from devon4x4 and they seemed to work http://www.devon4x4....emart&Itemid=14 I run upside down dislocation cones with my +5s and have never had a problem with them Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 22, 2011 Share Posted September 22, 2011 I run QT reverse relocation cones on mine and they are fantastic. Spring is held in at the top and the pointy cone goes on the bottom. I bought them after loosing a spring in Wales last year when I had the upper mounted ones. I've obviously not got Gwyn's ones, but I can vouch for the quality of the stuff he makes Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 24, 2011 Share Posted September 24, 2011 Most of the relocation 'cones' I have seen are the wrong shape. The point of the cone needs to be at the outermost edge of the spring seat in order to have the greatest chance of catching the spring as it returns off-centre. My old 90 had a right angle triangle of bent flat bar which never failed - though I only had a 2" lift. The bar went from the top spring seat outer edge directly down and then bent up to go at an angle directly to the inside edge of the spring seat. Does that make sense? Chris Quote Link to comment Share on other sites More sharing options...
landy andy. Posted September 24, 2011 Share Posted September 24, 2011 Gwyn's locate on the one side Andy Quote Link to comment Share on other sites More sharing options...
19MART82 Posted September 24, 2011 Share Posted September 24, 2011 before i fitted x springs i also ran reverse dislocation cones,relocated perfect every time and didnt seem to clunk and bang as much as the standard type cones Quote Link to comment Share on other sites More sharing options...
