will4x4 Posted October 4, 2011 Share Posted October 4, 2011 Hi does anyone fancy helping me change the cam belt on my 300tdi landy? Obviously ill pay them. Im happy to strip it so its ready and will buy all the parts required etc prior, i just need the timing pins to do the job and the correct torqe settings / tool when its all in? i have never done one bebefore however am perfectly capable to strip and re build it after. thanks in advance Quote Link to comment Share on other sites More sharing options...
Litch Posted October 4, 2011 Share Posted October 4, 2011 I've got all the necessary tools (crankshaft locking tool, timing pin kit, puller, deflection torque wrench etc) and would be perfectly willing to help but don't know where you are? I'm in Bedfordshire. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 4, 2011 Share Posted October 4, 2011 I believe he is in Farnham in Surrey.... Quote Link to comment Share on other sites More sharing options...
will4x4 Posted October 6, 2011 Author Share Posted October 6, 2011 yes i am that would be great. ill strip it this weekend and send you a pm if thats ok Quote Link to comment Share on other sites More sharing options...
Deej Posted October 6, 2011 Share Posted October 6, 2011 Shame I'm not at home at the minute, would be more than happy to help and I've got all the tools from doing this job on my disco a few months ago. If you want any advice on doing it give me a ring, I picked up quite a few useful tricks doing it myself. Quote Link to comment Share on other sites More sharing options...
Litch Posted October 6, 2011 Share Posted October 6, 2011 yes i am that would be great. ill strip it this weekend and send you a pm if thats ok If that reply was directed at me then I am afraid Surrey is too far. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 9, 2011 Share Posted October 9, 2011 Please - don't take it apart first. If you know how to take it apart, then it's not that difficult to put the thing back together Tech archive is your friend http://forums.lr4x4.com/index.php?showtopic=22319 Les. Quote Link to comment Share on other sites More sharing options...
will4x4 Posted October 10, 2011 Author Share Posted October 10, 2011 thanks les ill have a look. i took the cover off and its in a bad way. also removed power steering pump and water pump so will do thoes while im there. Quote Link to comment Share on other sites More sharing options...
Daan Posted October 10, 2011 Share Posted October 10, 2011 Took me 2 hours just before driving to 7 sisters.... But I'm getting (too) experienced! Les' guide is a good help. Daan Quote Link to comment Share on other sites More sharing options...
will4x4 Posted October 10, 2011 Author Share Posted October 10, 2011 hey Daan shame your not closer Were off to the seven sisters again this year November 25th i think but with the j33pclub.co.uk Quick question how do you tension the belt to 15NM? Surely doing the nuts up with a torque wrench is one thing but how do you know what place to tighten it? Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2011 Share Posted October 10, 2011 use a torque wrench one of the pointer type not click stop type, load to 15nm then while holding the torque, tighten the tensioner securing bolt or nut, there's a 1/2 inch square drive hole in the tensioner plate.as in the photo below Quote Link to comment Share on other sites More sharing options...
Daan Posted October 10, 2011 Share Posted October 10, 2011 Yes, thats the bit that is hard to achieve, even if you do have the right tools. You need 2 hands to torque it up while you nip up the nut with your other 2 hands. I do this bit on feel to be honest. What I find an issue is that the this setup slips over time, resulting in a loose belt. The torque specified in the manual is way too low for this to work in my opinion. But I am sure a specialist will come along and tell me different! Daan Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 10, 2011 Share Posted October 10, 2011 Just to be tad non-technical tighten the tensioner until the belt will deflect in one direction on the long side by 10mm with moderate finger pressure. That's as near as dammit Les Quote Link to comment Share on other sites More sharing options...
