Phil Hancock Posted February 10, 2013 Share Posted February 10, 2013 Yes it is, just on another enthusiast website, gives the same info with update part numbers there is a gasket on the TD engine, as shown in the lower end gasket kit here http://www.brit-car.co.uk/product.php?xProd=92455 So yet another link to a non genuine parts list that shows a gasket, THE GENUINE PARTS BOOK LISTS NO GASKET FOR THE TD, i know which i believe as an unreinforced sump flange(no doubling plates) will distort like hell with a gasket in there. Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2013 Share Posted February 10, 2013 my genuine paper parts bok for 110 1987 on shows the exact same diagram & part numbers & the britcar link shows a sump gasket, ONLY the Tdi engines use the hylomar 2000 sealant. look at the gaskets page for the TD engine even though it's a line dawing diagram it clearly shows a sump gasket in the genuine parts book. for Tdi engine it specifies the STC611 sealant in the parts description list. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 10, 2013 Share Posted February 10, 2013 That is a generic picture plate, the actual gaskets needed are shown in the detail page. P130 for the various parts shows no gasket. So which do you believe, a generic picture or the actual parts listing? Quote Link to comment Share on other sites More sharing options...
tukko Posted February 11, 2013 Author Share Posted February 11, 2013 Well i used sealant for the oil pan and this is working fine. No leaking what so ever. Another thing is that i changed from oil type. I use now 10W60 fully synthetic race oil from Kroon oil. This is working out very well. The engine runs more smooth and is more quiet. The oil will also give the engine a better protection against heat stress related problems. Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2013 Share Posted February 11, 2013 I'll go with the Brit-car link photo I posted, it has the matching part number with the parts book, if you want to use gasket sealant go ahead, it's not my engine. Quote Link to comment Share on other sites More sharing options...
tukko Posted February 11, 2013 Author Share Posted February 11, 2013 I'll go with the Brit-car link photo I posted, it has the matching part number with the parts book, if you want to use gasket sealant go ahead, it's not my engine. I did use a gasket on the first place when i rebuild the engine. After replacing the new oilpump i used sealant because the gasket was become so hard it cracked. Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2013 Share Posted February 11, 2013 that's fine Tukko, paper/card gaskets do go hard with age/heat, they can be very difficult to clean off at times of rebuilding. Quote Link to comment Share on other sites More sharing options...
tukko Posted February 11, 2013 Author Share Posted February 11, 2013 Some pictures of the LR90. They are taken at a 4x4 day at St. Isidorushoeve in Holland Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 11, 2013 Share Posted February 11, 2013 I'll go with the Brit-car link photo I posted, it has the matching part number with the parts book, if you want to use gasket sealant go ahead, it's not my engine.Fine carry, on but the parts book does not list a gasket or show one on the detail parts page. To show that the pictures alone cant be trusted over the parts list, look at a 1 ton salisbury series 3 front axle case pic, the pic shows a salisbury all right but for a 1 tonne which has integral swivels and spring over suspension! Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2013 Share Posted February 11, 2013 it doesn't list sealant either for the TD sump in the detal list, but it does for the tdi sump but doesn't show it in the diagram. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 11, 2013 Share Posted February 11, 2013 My money is on Ralph; questioning his knowledge is like not breathing Quote Link to comment Share on other sites More sharing options...
Diff Posted February 11, 2013 Share Posted February 11, 2013 My 1983 onwards genuine Land Rover 90-110-Defender workshop manual (paper book)states: 'On 2.25 engines, the sump is fitted with a gasket which should be renewed. ..... On later engines a bead of Hylosil RTV 102 black sealant should be applied to the sump joint face, approximately 7mm wide for a 2.5 or TD engine, approximately 2mm wide in the case of a Tdi engine.' Hope this clears up any confusion. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 12, 2013 Share Posted February 12, 2013 My 1983 onwards genuine Land Rover 90-110-Defender workshop manual (paper book)states: 'On 2.25 engines, the sump is fitted with a gasket which should be renewed. ..... On later engines a bead of Hylosil RTV 102 black sealant should be applied to the sump joint face, approximately 7mm wide for a 2.5 or TD engine, approximately 2mm wide in the case of a Tdi engine.' Hope this clears up any confusion. Regards, Diff. Thank you Diff much obliged, i rest my case that there is no gasket on a TD. IIRC my 14J has a gasket but is a doubling plate sump like a 2.25. The sumps can be identified by which has a gasket and which has sealer very easily. The gasket type sumps have spot welded doubling plates for the retaining bolts to bear on. The sealant sumps have a raised rib along the middle of the joint line and around the retaining bolt holes. Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2013 Share Posted February 12, 2013 in my defender workshop manual 1993 issue it says 2.25 & 2.5 n/a diesel have sump gaskets item 4 in page 78 http://www.retroanaconda.com/landrover/parts_books/110/2_engine_25P_25D_25TD_p17-167.pdf & the TD page 130 http://www.retroanaconda.com/landrover/parts_books/110/2_engine_25P_25D_25TD_p17-167.pdf makes no mention of a gasket or sealant [not even listed as an additional note] BUT LATER 2.5 engines use 7mm wide bead of Hylosill 102, therefore early TD engines would have used a sump gasket, then the later version would be sealant Hylosill 102, Tdi's use the hylomar 2000.so we are both correct BUT as no-one specified the early or later engine, the parts book does not mention hylosill 102 for any of the 2.5 pre tdi engines Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 13, 2013 Share Posted February 13, 2013 I knew Ralph would be right he's the man Quote Link to comment Share on other sites More sharing options...
tukko Posted March 15, 2013 Author Share Posted March 15, 2013 Time for a update. Since the overhaul last summer there are still a few difficulties with the engine. The injector pump is leaking a lot and that is an issue for the Dutch MOT. I bought a second hand pump for 50 and that did'nt workout at all. still leaking. The oil pressure is still not 100%. The turbo is working fine but he's blowing oil into the boost diapraghm. So i'm overthinking what to do? Do i going to buy a new pump(refurbished) aprox 300 pound or should i spend that money to a 200tdi? I bought the engine last year for 100 and spent 200 on overhaul and other stuff but i think this it. The next investment is a major one and i'm questionig my self is it worth the engine. Need some advice here, thanx Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2013 Share Posted March 15, 2013 you'd be better off, ditching the TD & sourcing a Tdi engine, either a ex-discovery 200 or a 300tdi, both can be made to fit older 90/110's. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 15, 2013 Share Posted March 15, 2013 Agreed. Quote Link to comment Share on other sites More sharing options...
tukko Posted March 15, 2013 Author Share Posted March 15, 2013 I've been reading Les topic about a 200tdi disco into a defender. How good are the 200 tdi's my NA and TD had problems with oilpressure at idle and the injectorpumps were leaking. How is that with the 200tdi? I also read that the turbo on a 200 is very good. Does the 200tdi have weak points? Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2013 Share Posted March 15, 2013 my 200 is 18 years old, never ben inside the crankcase, it's had a FIP rebuild,new injectors, turbo, cylinder head, still pulls well & in excess of 350,000 miles to it's credit. not found any weak points like the TD suffers from, my pistons/rings/conrods & crank bearings are still original LR fit as built in '93. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted March 15, 2013 Share Posted March 15, 2013 The TDi is an excellent engine, very strong and will last for well over 350,000Kms if you look after it. Quote Link to comment Share on other sites More sharing options...
tukko Posted March 16, 2013 Author Share Posted March 16, 2013 I'm to look at two engines this afternoon. One is a defender 200tdi and the other is a disco 200tdi. The seller will show them both running. This one of the two http://m.youtube.com/#/watch?v=XjqGkXpkT5k&desktop_uri=%2Fwatch%3Fv%3DXjqGkXpkT5k Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2013 Share Posted March 16, 2013 the Defender variant is the easiest to drop in, it'll sit on the existing mounts & join the gearbox, clutch is same as the TD has, exhaust downpipe on your TD can be persuaded to fit the TDI turbo exhaust outlett. Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2013 Share Posted March 16, 2013 tukko, the youtube link is not working Quote Link to comment Share on other sites More sharing options...
tukko Posted March 16, 2013 Author Share Posted March 16, 2013 tukko, the youtube link is not working Should work now Quote Link to comment Share on other sites More sharing options...
