Baz2236 Posted March 4, 2013 Share Posted March 4, 2013 Hi I got a 200 disco engine in my 90 and its a pain to get going in the morning. When I try and start it it fires straight away for a split second then dies it then takes alot of cranking to get it going again. to the point where it flattens the battery but if I put another battery on it will start. I have replaced the battery and tried disconnecting it during the night and connecitng it in the morning this has no affect I also changed the fuel filter cleaned all the earth points and starter has been replaced twice. Once it has started in the morning it will be fine all day but if I leave it for some time a few hours it somtimes struggles to start again. I do get it some heat before I try and start it usually about 20seconds before I crank it. Anyone got any ideas. I am ordered some glow plugs as I have never changed them. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 4, 2013 Share Posted March 4, 2013 Diesel leaking back? Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted March 4, 2013 Author Share Posted March 4, 2013 Thats what I am kinda thinking Any ideas How I check that. It runs well when its running Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 4, 2013 Share Posted March 4, 2013 Does sound like an air leak and lack of fuel. Is the fuel filter full or empty first thing in the morning before you try and start it? Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted March 4, 2013 Author Share Posted March 4, 2013 it near enough empty just a small amount in the bottom of the filter Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 4, 2013 Share Posted March 4, 2013 Somewhere its leaking back then. Check all the hoses for perishing on the outside for starters, I've got a rubber hose in very poor state, must change it. Then check all the jubilee clips (where fitted) are tight How long ago was the filter changed? If recent just check it hasn't got two large O rings in there (the old stuck on top of the new). Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted March 4, 2013 Author Share Posted March 4, 2013 I will get some new jubilee and pipe tomorrow and check them I have clips on the orginal pipe work and then it converts to the discovery style filter etc. so I will have a look Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 4, 2013 Share Posted March 4, 2013 Check the injector leak-off pipes. I've had these exact symptoms several times on both my 200Tdis, every time it has been the banjo bolts connecting the leak-off pipes to the injectors working loose. Tightening them up solves it, though once I had to buy new copper washers as well. Don't over-tighten the bolts, they snap very easily! Quote Link to comment Share on other sites More sharing options...
doda456 Posted March 4, 2013 Share Posted March 4, 2013 Mine started doing a similar thing, turns out the there was a loose connection on the pipe that runs from the fuel filter into the lift pump, A few turns at the lift pump end to tighten it, and she fires up instantly now And mine was also after an engine swap, so it is likely that something , is either loose or not seling properly Dan Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted March 4, 2013 Share Posted March 4, 2013 hi i would also check that the tank isnt getting a vacuum and sucking the fuel back from the filter by undoing the fuel cap and see if there is a hiss from the cap hth brian Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted March 4, 2013 Author Share Posted March 4, 2013 what would cause the tank to vacum Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 4, 2013 Share Posted March 4, 2013 A blocked breather. Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2013 Share Posted March 4, 2013 filler cap is vented & there is a fill neck breather hose to top of the tank. Quote Link to comment Share on other sites More sharing options...
