need4speed Posted March 11, 2013 Share Posted March 11, 2013 As title. On fitting the plenum base i discovered a loose stack/trumpet. It appears that its all the way home in the base so i assume i need to seal it in with something. Whats the best thing to use? Would i be best to seal them all seeing as i have 1 loose maybe others will follow?? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 11, 2013 Share Posted March 11, 2013 Clean both areas with brake cleaner Score surface to clean and give a key Use - Bearing sealer, loctite 243 Loctite 270 - JB weld (but get tube warm 1st or it will be too thick !) Nige Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 11, 2013 Author Share Posted March 11, 2013 Thanks Nige. Do you think its worth doing them all, or just the loose one? Is it a common prob? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 11, 2013 Share Posted March 11, 2013 I had 2 x l;oose on 5.2, whatever you use clean clean clean and must be il and fuel proof !If they don't move with a good grip / twist no, Nige Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 21, 2013 Share Posted March 21, 2013 Could chop 10mm of each one whilst youre there if yours is a 3.9 or larger Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 21, 2013 Share Posted March 21, 2013 ooo 4.6? maybe 15mm then, the 4.6 does respond to a little trumpet chop Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 21, 2013 Author Share Posted March 21, 2013 Hmmm. Im interested in this trumpet chopping you speak of! If its worthwhile i may as well do them while im in there with the sealer eh? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 21, 2013 Share Posted March 21, 2013 I thought trumpet chopping improved high revs at the detriment to low end grunt? or was it the other way around? The mind isn't what it used to be ..... Quote Link to comment Share on other sites More sharing options...
discomark10 Posted March 21, 2013 Share Posted March 21, 2013 I thought trumpet chopping improved high revs at the detriment to low end grunt? or was it the other way around? The mind isn't what it used to be ..... i think your right Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 21, 2013 Share Posted March 21, 2013 Longer intake tracts do improve low down torque, hence the bunch-of-bananas Thor manifold which gains quite a few torques. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 21, 2013 Share Posted March 21, 2013 Yes indeed true, longer intakes = torques however it is fair to say that the 4.6 has a good amount of torques already and the benefits of a top end increase outweigh the loss in torques from the low end. the more you chop the more top end you get with a flatter sub 2500 rpm zone. OP, it is definitely worth your research, and as i say already, on a 4.6 its almost a given that you should be removing some trumpet. cheers Quote Link to comment Share on other sites More sharing options...
