dailysleaze Posted April 16, 2013 Share Posted April 16, 2013 http://www.woolies-trim.co.uk/c-93-brushed-nylon.aspx Does anyone know which of the grey ones is the same colour as the standard headlining in a defender? Quote Link to comment Share on other sites More sharing options...
western Posted April 16, 2013 Share Posted April 16, 2013 isn't it meant to be 'off white' mine isn't grey ['89 110CSW] Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted April 16, 2013 Author Share Posted April 16, 2013 I don't really know to be honest. There is an off-white material but it's vinyl: http://www.woolies-trim.co.uk/c-94-vinyl.aspx which i don't think the headlining is? or is it? Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 16, 2013 Share Posted April 16, 2013 None of them are right, though grey would be closest. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted April 16, 2013 Share Posted April 16, 2013 I have a roll of it at work (we make the foam that goes into headlinings for pretty much every car made in Europe). I'm saving it for re-doing mine but I should be able to get more. PM me. Incidently I was at the company last week that make Defender headlinings (and seats) but it wasn't really the time to ask if I could pinch some! Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted April 16, 2013 Share Posted April 16, 2013 from what i can find, the headlining is dapple grey. but the empire grey is probably closest. have you thought about a new headlining? http://www.lasalle-trim.co.uk/welcome Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted April 17, 2013 Share Posted April 17, 2013 I've had my head lining panels out and I stripped the vinyl covering off them. I cleaned - scrubbed - the linings, to great benefit, and re-attached them to the head lining panels with Evostick type adhesive. The closest colour match is Empire Grey, but mine might be a little lighter, possible due to fading. It's a 1991 headlining after all! Mike Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted April 17, 2013 Author Share Posted April 17, 2013 I did initially think that I could remove the existing one and wash it, but i've read that the disintegrated foam backing causes the sagging and it wouldn't really stick properly without this. Is the foam backing necessary? Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted April 17, 2013 Share Posted April 17, 2013 The foam is essential. I have a roll of the stuff as supplied to JLR - foam backed, grey. I can get plenty more (we make the foam). FOC - collection only from Accrington/Lancs if you want some? Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted April 17, 2013 Share Posted April 17, 2013 If I remember correctly, mine had foam backing which crumbled as I separated the vinyl from the rigid panel. I removed it all before I scrubbed the vinyl and reattached the vinyl without any backing. So no, you do not need the foam. Mike Quote Link to comment Share on other sites More sharing options...
