jameshub Posted June 25, 2013 Share Posted June 25, 2013 I noticed on Sunday that my left rear wheel had oil splatter marks after I had driven it for an hour.......any though what has gone? (all other wheels are fine) Quote Link to comment Share on other sites More sharing options...
jbs Posted June 25, 2013 Share Posted June 25, 2013 Check your breather pipe and banjo bolt isn't blocked on top of the axle-9/16 AF spanner or 15mm 6 pointed socket(300 tdi and below) will undo it, make sure you take care when removing it as there should be two copper washers on the bolt-try not to lose them lol, you'll find If your breather is blocked it'll always leak oil out of that end of the axle-well mine does anyway, as theres no where for any pressure to build up to escape too hth John Quote Link to comment Share on other sites More sharing options...
jameshub Posted June 25, 2013 Author Share Posted June 25, 2013 Check your breather pipe and banjo bolt isn't blocked on top of the axle-9/16 AF spanner or 15mm 6 pointed socket(300 tdi and below) will undo it, make sure you take care when removing it as there should be two copper washers on the bolt-try not to lose them lol, you'll find If your breather is blocked it'll always leak oil out of that end of the axle-well mine does anyway, as theres no where for any pressure to build up to escape toohth John thanks John, I'll check that tonight Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 25, 2013 Share Posted June 25, 2013 Inside or outside of wheel? Inside - likely to be the hub seal leaking down to either a knackered seal or the blocked breather as above. Outside - the rubber cap split on the drive member (assuming yours has them!) Quote Link to comment Share on other sites More sharing options...
jameshub Posted June 25, 2013 Author Share Posted June 25, 2013 Inside or outside of wheel?Inside - likely to be the hub seal leaking down to either a knackered seal or the blocked breather as above. Outside - the rubber cap split on the drive member (assuming yours has them!) its outside and the black cap does look a bit cracked.......so would you recommend just changing that and seeing what happens over few days? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 25, 2013 Share Posted June 25, 2013 That's what I'd do. They are easy to damage, and they do crack over time as well. When its off, make sure the area it sits on is like and clean. The groove gets rust and dirt in it. Quote Link to comment Share on other sites More sharing options...
jameshub Posted June 25, 2013 Author Share Posted June 25, 2013 That's what I'd do. They are easy to damage, and they do crack over time as well. When its off, make sure the area it sits on is like and clean. The groove gets rust and dirt in it. thanks for that Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 25, 2013 Share Posted June 25, 2013 Change the cap. I bit of EP into the cap keeps the halfshaft splines lubricated. Check also that the outer end of the halfshaft isn't worn. The hub flange is supposed to be reasonably tight on the inside to the splines. If it's not tight there the halfshaft will push the cap off. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 25, 2013 Share Posted June 25, 2013 If it's leaking out the cap, also still check the breather after replacing the cap. Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted June 26, 2013 Share Posted June 26, 2013 How can I take the breather out in aTD5? I don't have a banjo, just a little hose that goes inside the axle case. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 26, 2013 Share Posted June 26, 2013 It does pull out, but be careful, they are plastic and can break. Not sure about TD5s, but you can fit push-fit airline connectors in the place of the older banjo type. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 26, 2013 Share Posted June 26, 2013 How can I take the breather out in aTD5? I don't have a banjo, just a little hose that goes inside the axle case. There should be a release ring around it, push this down while pulling the pipe up. Quote Link to comment Share on other sites More sharing options...
jameshub Posted July 9, 2013 Author Share Posted July 9, 2013 this is a picture of my wheel with the issue.....any thoughts? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 9, 2013 Share Posted July 9, 2013 Have you popped the cap off and cleaned the breather out? TBH, that doesn't very bad for an oil leak Pics here are more indicative of a serious failure: http://forums.lr4x4.com/index.php?showtopic=33908 Quote Link to comment Share on other sites More sharing options...
