farmer_ben Posted July 26, 2013 Share Posted July 26, 2013 ive got a 1986 110 with 2" lift ,285 75 16 tyres, 3degree castor correcion arms and it doesnt seem to wont to go in a straight line ! ive poly bushed the arms put new ball joints on and changed the steering box and had the tracking done and is still like it :-( any one know what to try next ?? thanks in advance ,ben Quote Link to comment Share on other sites More sharing options...
Diablo Posted July 26, 2013 Share Posted July 26, 2013 UJs on the steering column, wheel bearings. there's a good thread in the technical forum, called 'wobbly steering' which gives a host of symptoms and causes. My truck is currently unable to stay straight and that's due to a shagged wheel bearing osf, which I'm sorting tomorrow Quote Link to comment Share on other sites More sharing options...
Tanuki Posted July 26, 2013 Share Posted July 26, 2013 How does it wander? Does its wandering vary between power-on and overrun? Does it pull up straight under really hard braking? Was it a full 4-wheel alignment you had done, or just a front-end toe-in/toe-out check? (I ask because I once came across a LR that on investigation turned out to be an inch shorter on one side than the other following backstreet chassis-surgery: it never steered or stopped right!). Try swapping wheels side-to-side and front-to-rear. Check the preload on the steering-swivels too! Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted July 26, 2013 Share Posted July 26, 2013 panhard rod bushes? Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2013 Share Posted July 26, 2013 it shouldn't need castor corrected arms if the lift is only 2 inches, 3 inches and higher yes. what state are the swivel preloads in, if loose they can make steering very poor as can a poor panhard rod bush[es] Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted July 26, 2013 Share Posted July 26, 2013 Agree with Western, my last 110 had a 2" lift and standard arms and it handled like a sportscar. Well OK I lied a bit, but it certainly went generally in the direction I wanted it too. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted July 26, 2013 Share Posted July 26, 2013 might sound strange, but check the condition of not only the front radius arm bushes, but also the REAR trailing arm one, its surprising what a worn bush can do!! Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted July 26, 2013 Author Share Posted July 26, 2013 thanks for the help people I done all the bushes at the same time ,and only had the front tracking checked ,it drives like it has a poorly loaded trailer on it but when braking its fine and seems to be ok if I stay under 40mph lol Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted July 27, 2013 Share Posted July 27, 2013 What tyres and pressures are you running?? Quote Link to comment Share on other sites More sharing options...
L835 Posted July 28, 2013 Share Posted July 28, 2013 Loose drop arm nut? Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted July 29, 2013 Author Share Posted July 29, 2013 im running 285 75 16 insa turbo special tracks with 35psi in the front and 40psi on the back ,drop arm is fine ,ive just borght a return to center steering shock see if that makes any differance :-) Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted July 29, 2013 Share Posted July 29, 2013 Mine is on 265-75x16 BFG Muds, and it doesn't like 40psi in the back, it seems very skittish. Handles best on 36psi all round, even with a heavy trailer and tyres are wearing fine. So I would try lowering the rear pressure a bit. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted July 29, 2013 Share Posted July 29, 2013 A friend mentioned the other day that her ex military 110 was wandering badly at speed, I checked the tyre pressures, she had 28 front, 48rear!!!! I lowered that to 35, and she said its now so much more stable, and she never puts anything in the back, My advice, try lower pressure all round!! Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2013 Share Posted July 29, 2013 try dropping the front tyre pressure to 30 or 28, my 110 runs 255/85 MT's the fronts are only at 28psi, rears at 40psi [400kg recovery kit onboard all the time] front pressure doesn't go any higher what ever the load. Quote Link to comment Share on other sites More sharing options...
Diff Posted July 29, 2013 Share Posted July 29, 2013 What width rims do you have? Minimum width is 7.5 inch, but they will work better on 8inch wide rims. If they are on 7 inch rims, it won't help with the steering issues, but may not be the primary cause. The tyres you have are very aggressive remoulds and won't handle well compared to a regular all terrain or even mud terrain. The wide tyres make things worse too! It is possible that a lot of factors are contributing to your steering woes. Just go through things methodically. If you can, borrow someone elses wheel and tyres, and see if it makes any difference. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted July 30, 2013 Author Share Posted July 30, 2013 thanks for the help I have swapped the front wheels for the back and lowered the pressures and it is much better ! thanks :-) Quote Link to comment Share on other sites More sharing options...
