cookie64 Posted August 14, 2013 Share Posted August 14, 2013 well it seems to be that time of year again where i have propshaft failure probably should have re greased them after her being laid up for 7 months whoops anway id like to get some decent wide angle props this time instead of the cheap britpart poo that was on it does anyone have any suggestions as to the best i can get, including value for money? gwyn lewis? bailey morris? thanks tom Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted August 14, 2013 Share Posted August 14, 2013 i have a cheapo wide angle (theyre all the same unless you buy a bailey morris IMO) and its been superb. Just buy it, fit it, use it til a joint goes funny and then only replace with GKN joints, the rest is just metal. Saves yourself at least £100 per propshaft that way. My front shaft cooks it's top joint every few months/500 miles because it is very close to the oversize exhaust (v8) but as far as i can remember ive not replaced the bottom UJ since ive had the prop so fair enough to whatever joint was in it. I'm pretty sure it was in a britpart bag but i just bought the cheapest new one available at the time off ebay, was around 90 quid, never looked back Quote Link to comment Share on other sites More sharing options...
jbs Posted August 14, 2013 Share Posted August 14, 2013 I've just bought from Gwyn lewis a wide angle prop for the rear and it's spot on-these are made by bailey morris for them anyway, they do have from what I can remember HD UJ's in them John Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 16, 2013 Share Posted August 16, 2013 I got mine from Gwyn Lewis too, they have not failed yet. Quote Link to comment Share on other sites More sharing options...
jbs Posted August 16, 2013 Share Posted August 16, 2013 I got mine from Gwyn Lewis too, they have not failed yet. How long and how hard have you worked it? John Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 17, 2013 Share Posted August 17, 2013 Pretty hard I guess I mean I don't do trials or anything comp things. Where I live is pretty off road and I take it along old logging roads allot, tow allot of heavy stuff, carry heavy things. I have his comp suspension on the truck too, but ended up putting twin shocks on the back (which really help when carrying heavy things with a heavy trailer too along these roads. In the summer it can get up to +30º, in the winter it can go as low as -40º (but mostly around - 15 ishº) Grease them every start of summer, and start of winter, that's it pretty much. Quote Link to comment Share on other sites More sharing options...
jbs Posted August 17, 2013 Share Posted August 17, 2013 Badger, How long have you had them?, The reason I ask Is I've now got two of Gwyns props(bailey morris made ones) one wide angle rear and a double cardon one for the front and won't be extreme with them-I was sick and tired of rebuilding second hand stuff I had lying about so i went for new hence why I was asking about how long you'd had them. John Quote Link to comment Share on other sites More sharing options...
cookie64 Posted August 17, 2013 Author Share Posted August 17, 2013 thanks for the replys guys for 5 years ive been doing the first option, rebuilding each uj when it fails but am fed up of it now so prepared to spend some money, probably buy some bailey morris ones i think my rebuild cost has just hit about £5K haha :s Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 17, 2013 Share Posted August 17, 2013 Over 4 years now Quote Link to comment Share on other sites More sharing options...
rick Posted August 18, 2013 Share Posted August 18, 2013 FWIW the Bailey-Morris shafts have been failing here, or at least their DC shafts have. The DC centreing bearing can't take sustained speeds/loads. Have aTom Wood shaft coming from the US. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted August 19, 2013 Share Posted August 19, 2013 Just inspected a pair of bailey Morris shafts yesterday that came through Glyn Lewis, yes they are substantially different to the cheapo wide angle version I have fitted to my car. Quote Link to comment Share on other sites More sharing options...
zim Posted August 19, 2013 Share Posted August 19, 2013 I've run bailey Morris on my comp truck for a whole, touch wood always been perfect. G Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 19, 2013 Share Posted August 19, 2013 Gwyn Lewis sells two types (or used to). The blue ones which I have are GKN made, not BM. Quote Link to comment Share on other sites More sharing options...
ToyRoverlander Posted August 19, 2013 Share Posted August 19, 2013 I had mine made by Dunning&Fairbank. Rear one is a wide angle DC shaft with 110mm slider, front shaft is a wide angle one with a 180mm slider. Both custom lenght. Good quality. Front one has been on for at least 4years (20.000 miles or so) and is still perfect. Haven't even have to replace a u-joint yet. Rear shaft is more than a year old now with I guess 8.000 miles on it and is like new. Fair price as well. Front shaft was 185pounds, rear one was 235pounds IIRC. Quote Link to comment Share on other sites More sharing options...
robbie1717 Posted August 22, 2013 Share Posted August 22, 2013 i've seen Paddocks sell BM Props too - whats the diff between theirs and the ones GL sells? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 22, 2013 Share Posted August 22, 2013 Probably not much. My Gwyn Lewis ones are good, though I had to change all four UJs last year (£££!). Bought the replacements directly from BM, as it was the same price as going via Gwyn and he had none at the time. Quote Link to comment Share on other sites More sharing options...
