Keeper96 Posted November 1, 2013 Share Posted November 1, 2013 Hi guys My 90 was leaking but carefull application of a tiny bit of silicon (read copious amounts) has stopped that problem, however there is still water on the inside that condenses and covers the roof in the load area, what's the best way to dry the inside out? Cheers Quote Link to comment Share on other sites More sharing options...
=jon= Posted November 1, 2013 Share Posted November 1, 2013 Even if it's not leaking, the air temp difference and the cold metal roof will cause condensation... The best way is to line the roof somehow - I used laminate floor underlay (1mm thick plastic closed cell foam type stuff) with spray adhesive, it helped a lot... But make sure you use high temp adhesive or it'll all fall off in the summer! Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted November 1, 2013 Share Posted November 1, 2013 Thermal bubble wrap Sorted..... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 1, 2013 Share Posted November 1, 2013 Is that the same stuff Les (Brock) used ? Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted November 1, 2013 Author Share Posted November 1, 2013 Thanks guys, I know that the temp difference will cause condensation but there is still a lot of residual water from the leaks that is adding to the condensation. What's the best way to get rid of this? Cheers Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 1, 2013 Share Posted November 1, 2013 dehumidifier, but unless you are 100% certain you've sealed all the leaks, it'll only be a short term solution. I thought I'd got all of Kettle's leaks....turns out not.... Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted November 1, 2013 Author Share Posted November 1, 2013 I'm pretty sure, it's just hard to tell with the amount of water still on the roof. It's had the hose pipe test and not leaked any more though so fingers crossed haha Cheers Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 1, 2013 Share Posted November 1, 2013 Is that the same stuff Les (Brock) used ? Perhaps not ? Les's stuff is here: http://forums.lr4x4.com/index.php?showtopic=67196&page=18 Quote Link to comment Share on other sites More sharing options...
studmuffin Posted November 1, 2013 Share Posted November 1, 2013 Hi guys My 90 was leaking but carefull application of a tiny bit of silicon (read copious amounts) has stopped that problem, however there is still water on the inside that condenses and covers the roof in the load area, what's the best way to dry the inside out? Cheers very impressed that you have stopped the leaks. Has anybody tried Sugru ??? Just bought some anyway but interested in feedback. Barry Quote Link to comment Share on other sites More sharing options...
Spearos Posted November 1, 2013 Share Posted November 1, 2013 Thanks guys, I know that the temp difference will cause condensation but there is still a lot of residual water from the leaks that is adding to the condensation. What's the best way to get rid of this? Cheers I've had this problem a few times, what I do is towel off as much water as I can and then drive with the V8 blasting (gently blowing) hot air in the vehicle! I also bought on of these : http://www.amazon.co.uk/Wenko-77780100-Damp-Killer-Anthracite/dp/B0030GB32K/ref=sr_1_19?s=kitchen&ie=UTF8&qid=1383336018&sr=1-19&keywords=dehumidifier+car Surprising how much water it absorbs, it almost doubles in weight! One day I'll get round to applying the camping mats I got from the pound shop.... Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 1, 2013 Share Posted November 1, 2013 There's truly no such thing as a non-leaky Defender. Thankfully, Land-Rover never got any UK military contracts to build ships/submarines. Even after you've sealed all the obvious leaks it can take some time [months!] for the historically absorbed dampness to migrate out of the seats/floor-mats/foam dash-coverings/door-cards etc. You can accelerate this by sticking a small fan-heater [1Kw or so] and a dehumidifier in the cab and leaving them running overnight once a week.. Even so, the humidity you exhale/perspire during daily driving and which remains inside when you park up will condense overnight on the roof/windows if there's any kind of frost outside. This is one of the great things about air-conditioning: it dehumidifies the incoming air and so helps prevent the buildup of trapped moisture. Quote Link to comment Share on other sites More sharing options...
jbs Posted November 2, 2013 Share Posted November 2, 2013 The last time I had any form of condensation was during the time without a headlining In my 110, Since I've had a headlining/roof lining in my 90, I've not suffered with any form of condensation John Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted November 2, 2013 Share Posted November 2, 2013 Is that the same stuff Les (Brock) used ? Hi Anderzander! How's it going mate? This is the stuff I used.... http://www.ebay.co.uk/itm/Double-Foil-Double-Bubble-Wrap-Aluminum-Insulation-Roll-1-2m-x-25m-Loft-Wall-/151155151494?pt=LH_DefaultDomain_3&hash=item23318c9286 Cheers Gaz Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 2, 2013 Share Posted November 2, 2013 Good thanks Gaz. Thank you for the link too. What's that like for noise ? Did you use something like trimfix to stick it on ? Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted November 2, 2013 Share Posted November 2, 2013 Good thanks Gaz. Thank you for the link too. What's that like for noise ? Did you use something like trimfix to stick it on ? Yes mate, Dunlop trim spray...dead easy to do apart from the headache from the fumes Ha Ha! And like Jbs says, I got a second hand headlining and retrimmed it, that plus the insulation did reduce noise some! Biggest difference I can see is, it is not stinking hot in the summer and in winter, mine is easy to scrape the ice off when everyone else's car in the works car park is frozen up!.... Quote Link to comment Share on other sites More sharing options...
