white90 Posted October 17, 2006 Share Posted October 17, 2006 X2 Doors push button doors must be dent/rust free x2 outer wing outer skins prefer 300TDI> would take more than 2 if available x2 Door skins if I can't find doors 300TDI fitted rubber mat Drivers side (hole free) the one that is fitted in 90s with no carpet pr front wheel arch eyebrows (tear free) 255/85/16 BFG MT part worn or New 2L AFFF fire extinguisher FIA master battery cut off with Alternator protection diode/connections Collect a reinforced clutch release arm if someone remembers it x2 headlamp surrounds for the same person above Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 17, 2006 Share Posted October 17, 2006 x2 outer wing outer skins prefer 300TDI> would take more than 2 if available I might know of something that might interest you and will last a little better than the original ones Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 17, 2006 Share Posted October 17, 2006 Collect a reinforced clutch release arm if someone remembers it I'll paint it flourescent pink if you don't watch it!! Les. Quote Link to comment Share on other sites More sharing options...
Andy Posted October 17, 2006 Share Posted October 17, 2006 better than painting it orange! Quote Link to comment Share on other sites More sharing options...
white90 Posted October 17, 2006 Author Share Posted October 17, 2006 I'll paint it flourescent pink if you don't watch it!! Les. to match your Sofa? Quote Link to comment Share on other sites More sharing options...
JST Posted October 17, 2006 Share Posted October 17, 2006 ditto, as Tony pointed out on another thread, i am after some wing skins Quote Link to comment Share on other sites More sharing options...
TJ101 Posted October 17, 2006 Share Posted October 17, 2006 ditto, as Tony pointed out on another thread, i am after some wing skins and here as well !!!! Quote Link to comment Share on other sites More sharing options...
ciderman Posted October 17, 2006 Share Posted October 17, 2006 looks like the hunt is on for wing skins, I am after a couple ,not fussed about little dents , and they have to be pre Td ones if possible. I am up there selling so I will have a quick scout before the mad rush. Quote Link to comment Share on other sites More sharing options...
Countax Posted October 17, 2006 Share Posted October 17, 2006 Tony, I have a rusty NS door with a good skin that I just took of my 1991 200TDi. I will check it out and confirm later what dings, if any it has. If you think you can take the skin off and use it then its yours for free. I also have the drivers door, again the frames gone, but the skin might be ok. let me know if you think they are usable and i will bring them to OS. If not, just say so, i won't be offended. Nigel Quote Link to comment Share on other sites More sharing options...
simonr Posted October 17, 2006 Share Posted October 17, 2006 I'm also looking for push button doors or door skins (both sides). Wing mirror arms. Typical - I've fitted unbreakable heads, now just break the arms instead! A pair of narrow type front hockey sticks. Si Quote Link to comment Share on other sites More sharing options...
Countax Posted October 17, 2006 Share Posted October 17, 2006 Tony,I have a rusty NS door with a good skin that I just took of my 1991 200TDi. I will check it out and confirm later what dings, if any it has. If you think you can take the skin off and use it then its yours for free. I also have the drivers door, again the frames gone, but the skin might be ok. let me know if you think they are usable and i will bring them to OS. If not, just say so, i won't be offended. Nigel Oh, i forgot to add my wish list...... 2 x D90 side panels with windows. Ideally genuine LR sliding windows with panels in Post Office red Quote Link to comment Share on other sites More sharing options...
white90 Posted October 17, 2006 Author Share Posted October 17, 2006 Nigel thanks but I don't thank I could remove then refit a skin, as I'll have to grind the edges to get the old one off. thanks for the offer though. Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 18, 2006 Share Posted October 18, 2006 ??????????? Grind the edges???? I just prise them up with a screwdriver, drill out the pop rivets, and then just take the skins off. Its only soft ally. Do it all the time when the frames need welding up. You can then re-fit them and dress the crease back down again with a hammer and dolly. Easy peasy........ Jon Quote Link to comment Share on other sites More sharing options...
